  1. When I burn DVD copies should I select
    1VD Video or
    2VD ROM UDF/Iso
    Also should JOL LIET be on?oFF
    Differant guides say differant Things.
    I am burning DVD back ups VIDEO_TS files.Using Pioneer A04 burner
  2. I always burn DVD Video, joliet off ( for newer version of Nero at 5.5.8.0 and up ), before I used to do UDF/ ISO ( still with joliet off ) with Earlier versions of Nero.
  3. hi jus aquik question,wen u burn a dvd with nero,duz it burn all the chapter,menus etc...
    or duz it jus burn the movie so its recognised as a dvd in a standalone player??
    tanx spida!
    May 2001
    This route is the SAFEST to retain compatibility. If you don't have the latest NERO, you should download it today (Ver 5.5.8.2) and upgrade.
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    spida: you must author the dvd with another software before burning with nero.
  6. ok,so ,what prog do i need,wher can i get it from,and how do i author it so then i can burn it as aa normal dvd with menu ,features etc..??
    Tanx a lot 4 that!!
    Spida!
  7. why must you author with a differant program 1st.
    I rip with DVD decrypter then put the VIDEO_TS and a "made up" AUDIO_TS folder into NERO select DVD Video and burn.Using A PIONEER A04 and it WORKS!!!
    (Well at least it plays on my PIONEER 444 DVD player.}
    Will I get more compatibility using differant PROGRAMS for burning or even differant Brands of Media??????
  8. I'm a MEGA Super Moderator Baldrick's Avatar
    if you rip you don't need to author because it is already done...but if you don't have any vobs and ifos you must author.
    spida: www.vcdhelp.com/author.htm#dvd and also checkout doom9s minidvds guides for more advanced dvd authoring tools like dvdmaestro,scenarist...
