I am using AviUtil now. It works but is tedious. For one, there is no ability to cross-fade audio. I do need the multiple layers it has. I mostly only do simple edits. Cut-n-paste, cross-fade and fade-to-black. When I try to split the audio from the video, it never gets the timings right.
Is one of the free ones on here better now?
KdenLive is open source and free.. and it's a great software for multitrack audio (and video) editing. It's very easy to cross-fade (in/out) video and audio tracks directly from the timeline.. in a "visual way", simply dragging up and down some "points" where every fade should start/end. And if you need more advanced editing there is a lot more the software offers you.. Kden is quite more powerful and versatile than its ..cousin.. "Shotcut".
Using potplayer to capture switch but no audio
By ReactiveSlime in forum AudioReplies: 5Last Post: 18th Nov 2023, 05:18 -
AviUtil problem importing .wmv in Windows 10
By ChasVideo in forum EditingReplies: 13Last Post: 29th Aug 2021, 18:29 -
Unable to switch input source
By Desve in forum DVD & Blu-ray RecordersReplies: 5Last Post: 2nd Aug 2019, 13:54 -
[SOLVED] [ffmpeg] Why does it ignore the -to switch?
By yetanotherlogin in forum EditingReplies: 5Last Post: 13th May 2018, 20:22 -
Aviutil
By foldbck123 in forum Newbie / General discussionsReplies: 0Last Post: 1st Dec 2017, 12:28
