I am after a subtitle editor that is easy to use? I've tried Subtitle Edit but it insists on doing things I don't want to do, such as changing the layout of the original text as well as the spelling!
All I want to do is import some subtitles from one video to a slightly extended one, change the starting point of some of the text, and occasionally let it appear a bit longer?
For Subtitle Edit: you probably have some options enabled for auto-correction/formatting.
Anyway.. i use KaiNote : it's also free and has very powerful tools, especially for re-sync tasks, but at the beginning you have to spend quite some time to familiarize yourself with its complex interface full of buttons and understand how those tools work.Last edited by krykmoon; 25th May 2022 at 08:37.
It's not clear whether your subtitles are text- or image-based. For text, see krykmoon's post.
Should your subtitles be image-based SUP or XML/PNG, SE has the option to perform time-based edits (like syncing) without touching the original images.
Any subtitle editor on Chrome OS?
By Hakunamatata67 in forum SubtitleReplies: 1Last Post: 2nd Jun 2021, 07:24 -
Easy to use MKV Editor
By efiste2 in forum EditingReplies: 2Last Post: 23rd Apr 2021, 21:20 -
How to save files as .SUP from Subtitle Editor?
By DiodE in forum SubtitleReplies: 4Last Post: 14th Nov 2020, 06:21 -
[editing] easy switching between clips in VSDC or another free editor
By PawelK in forum EditingReplies: 5Last Post: 8th Sep 2019, 10:53 -
Gaupol - Subtitle Editor
By devilcoelhodog in forum SubtitleReplies: 4Last Post: 9th Jun 2017, 14:28
