Hi guys Is there way to crop multiple pictures from same opened picture in ps 2022. I have one big picture (map ) that I need to crop in smaller parts A4 format ( to make 15 pages booklet) .
I now open picture crop the part save then undo than crop again another part then save then undo and so on. The problem is crop box is not saved ( there was some on line tutorial with macro but I couldn't make it to work).
Basically i need the crop box( fix width and height) to be saved so I can just slide it on the picture and cut parts that will be saved as individual pictures from one big picture
Iirc, there is built-in a straightforward batch automation action to do that for you. No need to reinvent the wheel.
Scott -
I cant find something like that in menus and I am not trying to make batch of multiple pictures in a row but one picture to slice it in more parts and individually save as pictures. Is there any tutorial how to do this because i couldn't find one that do specific thing there is plenty of automatic batch processing or script which is not what I am looking forIirc, there is built-in a straightforward batch automation action to do that for you. No need to reinvent the wheel.
Phillips bdp2190/05 BD regions
By jack616 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 10th Dec 2021, 06:07 -
Newbie - want to create youtube videos witrh multiple Picture in Picture
By peligroraton in forum Newbie / General discussionsReplies: 4Last Post: 7th Jan 2020, 10:16 -
DVD PAL Regions
By jseo13579 in forum Software PlayingReplies: 4Last Post: 11th Apr 2019, 18:24 -
Batch combining multiple audio files with same picture to create mp4 files
By MD_89 in forum AudioReplies: 25Last Post: 1st Dec 2018, 23:29 -
I need suggestions for an all-regions DVD player that does SECAM
By Senex in forum DVD & Blu-ray PlayersReplies: 10Last Post: 19th Mar 2018, 11:05
