I have an image sequence which I'm trying to encode as 50fps, but it's coming out as 25fps with the video twice as long as it should be.
Can some intelligent sort diagnose the error in my command line?
Normally I do 25fps, and I've just tried to guess my way around it. Looking for video bitrate of 5000, so I assume that's one part needing changed. However I can't work out why the video is just jerking along at 25fps and half the speed it should be.
ffmpeg -i c:\video\bs\%06d.tif -vf scale=970:720 -level 4.1 -r 50 -b_strategy 2 -8x8dct 1 -fast-pskip 0 -pix_fmt yuv420p -bf 15 -b-pyramid normal -me_method umh -subq 11 -me_range 64 -mbtree 1 -rc-lookahead 250 -keyint_min 50 -direct-pred auto -partitions all -trellis 2 -mixed-refs 1 -aq-mode 1 -aq-strength 1.15 -deblock -1 -vcodec libx264 -profile:v high444 -refs 12 -vb 2500k -maxrate 6250k -bufsize 7812k -preset veryslow -pass 1 -an pass1.mkv
You want to put -r 50 before -i..., not after. Otherwise ffmpeg will assume 25 fps for the input then double it (by duplicating each frame) to 50 fps for the output.
FFMPEG x265 encoding wrong settings for some sources
By tony95 in forum Video ConversionReplies: 4Last Post: 10th Dec 2021, 12:11 -
FFmpeg wrong write date question
By lacahung in forum Video ConversionReplies: 2Last Post: 14th Apr 2021, 11:04 -
Wrong framerate during FFMPEG concatenation
By qo4on in forum Newbie / General discussionsReplies: 21Last Post: 28th Apr 2020, 06:57 -
[Edited]
By Anonymous843423 in forum Video ConversionReplies: 2Last Post: 7th Feb 2019, 09:34 -
FFMpeg reports wrong video size ?
By alexander121 in forum Video ConversionReplies: 3Last Post: 13th Oct 2017, 10:03
