Hello I'd like to use ffmpeg to change the audio speed in order to mux two bluray (having different fps), minimizing the quality loss (maybe lossless). I' like to use foss software only (I like ffmpeg).
1) could you suggest me some guide to learn how to encode audio without losses?
2) if I start from a lossless codec like DDP, TrueHD or DTS MA, should I convert them to a lossless codec? Which one? What about sampling, bit depth etc..?
3) if I start from a lossy codec like AC3, or DTS Core, should I convert them to a lossy codec? Which one? What about sampling, bit depth etc..?
Any additional resource is appreciated.
Results 1 to 1 of 1
Any sound and mostly dts & dts-hd to ac3
By fits79 in forum AudioReplies: 42Last Post: 23rd May 2024, 01:43 -
How to batch reduce DTS-HD to DTS core with MKVmerge? (or any other way)
By tijgert in forum Newbie / General discussionsReplies: 5Last Post: 24th May 2022, 03:51 -
Convert mkv with DTS HD MA to mkv with DTS core - Mac user
By bardian in forum MacReplies: 3Last Post: 9th Apr 2020, 15:30 -
Why the rippers usually change the original bit of depth (DTS Core)?
By Enrik in forum AudioReplies: 10Last Post: 26th Jul 2019, 18:53 -
What is better DTS Core @ 1509 Kbps or AAC @ 700-1000 Kbps from DTS-HD MA
By vash1 in forum Newbie / General discussionsReplies: 5Last Post: 14th Nov 2018, 13:29
