When i have inserted a tape it only makes a notice about trying to load the tape then the motor goes off. I have had this problem before and it seems to fix itself after some weeks. What can the problem be?
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
Results 1 to 15 of 15
I'm not sure i understand but if your problem is about loading the tape, i'd say it's a lack of grease somewhere (gears, base of the guide..) grease tend to dry. You'd have to clean the old one, and put some new. If you remove the front panel you will see gears on the right.
Could be also a belt problem (they become loose over time, they don't grip that much)*** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE -
You can post pictures directly to this site,the other one is very slow to load pics.Check the main belt on the bottom of the vcr if you can see it.
Is the VCR model # a secret?
https://www.youtube.com/watch?v=eQ0I2GPxlaw&ab_channel=12voltvids
see around the 20min mark*** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE -
Looks like the reel is not even wrapped around the drum so i say it's a belt issue, it might be loose, don't provide enough torque. Time to swap it
A year ago I asked for a model # for a specific reason related to VCR shuttdown but you ignored the request as if I was asking for a favor, Well good luck on your quest.
How do i fix the belt? It is correct that the tape don't get wrapped around the drum.
You replace the belt,it can't be fixed if it's too loose.
vhs tape will NOT move through vhs recorder at all
By tepeco in forum RestorationReplies: 52Last Post: 24th Oct 2022, 13:31 -
VHS player ejecting cassettes immediately and tape not being released
By itm2 in forum RestorationReplies: 3Last Post: 23rd Aug 2020, 15:49 -
Before you digitize that VHS tape, check the VHS VAULT first!
By babygdav in forum Latest Video NewsReplies: 20Last Post: 22nd Jun 2020, 17:33 -
vhs tape question, 1/2 tape is fine and 1/2 way thru gets lines
By tomthetank in forum Newbie / General discussionsReplies: 8Last Post: 13th Jan 2019, 08:14 -
tape won't load. jvc gr-axm225
By fie in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 23rd Oct 2018, 13:19
