I ran a command such as this
ffmpeg -y -I input.mkv -map 0:v -c:v copy -map 0:a -c:a:0 copy -map 0:a -c:a:1 ac3 -map 0:1 -c
:1 copy output.mkv
When I view, the output.mkv in MKVToolNix GUI program, I see this
[Attachment 64913 - Click to enlarge]
Can someone explain me what are Global Tags and Tags are? I didn’t add them.
Also SubRip/SRT is displayed as SubStationAlpha. What is causing this renaming? How can I keep the same name?
Thanks in advance for your time and help.
Joe
see this reddit thread - https://www.reddit.com/r/ffmpeg/comments/g99omc/how_to_prevent_ffmpeg_from_writing_this_globaltags/
you can remove the Global Tags if you wish. -
Global tags are all tags that are not associated or part of a specific audio/video/subtitle stream.
You can't that's just how mkvtoolnix displays the used format, other tools can display the format using a different name,.Also SubRip/SRT is displayed as SubStationAlpha. What is causing this renaming? How can I keep the same nameusers currently on my ignore list: deadrats, Stears555, marcorocchini
Tags in Matroska container - required or not?
By JosephTocco in forum Newbie / General discussionsReplies: 0Last Post: 1st Oct 2021, 08:50 -
How do I prevent MKVToolNix from creating global tags?
By fltk10 in forum Newbie / General discussionsReplies: 4Last Post: 13th Sep 2021, 09:00 -
Is converting VSFilterMod tags to mainstream tags possible?
By zerxes96 in forum SubtitleReplies: 0Last Post: 29th Apr 2020, 19:39 -
Audio file tags
By alex5908 in forum MediaReplies: 0Last Post: 25th Aug 2019, 12:51 -
Tags that are added wnen converted in any Software
By Bernix in forum Newbie / General discussionsReplies: 0Last Post: 27th Jan 2018, 06:25
:1 -c
