Hello. I'd like to merge sentences that are split over different lines in SRT files into one sentence.
Subtitle Edit's "Merge sentences" under the Auto-translate menu is almost good, but it doesn't seem to work if longer time has passed between the sentences that are split over different lines.
For example, “Merge sentences” can handle this just fine:
1
00:00:01,000 --> 00:00:03,000
Hello
2
00:00:03,024 --> 00:00:05,024
this is a test.
3
00:00:05,048 --> 00:00:07,048
Hello,
4
00:00:07,072 --> 00:00:09,072
this is a test.
Output:
1
00:00:01,000 --> 00:00:05,024
Hello this is a test.
2
00:00:05,048 --> 00:00:09,072
Hello, this is a test.
However, this doesn’t work:
1
Hello
2
00:00:03,324 --> 00:00:05,024
this is a test.
3
Hello,
4
00:00:07,372 --> 00:00:09,072
this is a test.
Does anyone know any other way to join sentences? It's okay if the resulting SRT ends up with very long lines.
Maybe you use an old version? I tried; SE 3.6.5 has no problems with the 4 lines you posted.
Merge .srt & .mp4 without encoding video & audio?
By alexeliasson in forum SubtitleReplies: 9Last Post: 11th Jan 2021, 11:42 -
2 Blu Ray Discs, 1 srt subtitle file, do I have to rip and merge both discs
By sethhuner in forum Blu-ray RippingReplies: 5Last Post: 27th Jun 2020, 11:24 -
How to merge segmented webvtt subtitle files and output to SRT file?
By smokeweedevryday in forum SubtitleReplies: 0Last Post: 8th Mar 2020, 11:29 -
Trimming sentences in SRT files...
By thebib62 in forum SubtitleReplies: 2Last Post: 25th Oct 2019, 02:59 -
Merge SRT entries with duplicate timestamps?
By bizzybody in forum SubtitleReplies: 1Last Post: 12th Apr 2019, 06:49
