Hi,
So I need to blur the text of several videos, I usually use Movavi Video Coverter to edit/split files because there's almost no quality loss, sadly it doesn't have a option for blurring.
I know how to do it with Sony Vegas Pro, but I've tried every setting possible and there's always a visible quality loss after rendering.
Does anyone know of a free option to blur a clip, with no or very minimal quality loss?
Thank you.
If you've tried uncompressed, and there still is visible quality loss, it suggests a problem with your settings or project setup. Perhaps a mismatch with the asset(s), project and/or export settings, or inadvertently some other operation being applied
Otherwise, for lossy compression ,use a higher bitrate or better encoder. The bundled ones for AVC, HEVC are not very good. eg. with voukoder plugin you can use libx264, libx265 -
Yes uncompressed options , and 3rd party lossless codecs like lagarith, ut video etc.. which need to be installed
If you use uncompressed or lossless, and you still see visible loss, you've already ruled out compression as the reason . The reason has to be something else, such as your project settings, or export settings (e.g. maybe different resolution, or framerate and you have frameblending on)
Vegas works in RGB, so if your asset is YUV, there is technically some loss, but it should not be visible loss (when you "see" something it has been converted to RGB anyways, for display) -
If there is a mismatched setting like a different resolution - of course there is going to be loss
But it's a lossless codec. If there still is "very minimal" loss, you still have something configured incorrectly, or some other issue like playback problem. Lossless means no loss.
Yes AVI only , although it might be able to force it into a MKV container
Camera out of focus. Video Blur after. Is there any scripts to fix this?
By JeremyVN in forum EditingReplies: 1Last Post: 25th Mar 2022, 11:04 -
Add blur to cover the video defect in ripping
By hintlou in forum DVD RippingReplies: 15Last Post: 24th Feb 2020, 05:33 -
How to blur objects in video
By jseo13579 in forum EditingReplies: 6Last Post: 26th Oct 2019, 08:38 -
How to remove blur effect in video
By OldJohn in forum EditingReplies: 4Last Post: 27th Sep 2018, 13:35 -
Does turning off sharpening blur the source video?
By Hypersonic1 in forum Capturing and VCRReplies: 6Last Post: 3rd Dec 2017, 18:37
