Hey, I'm searching for a tool that can sync an audio track with comparing two audio tracks of another language.
I have a video with a German and a Japenese audio track. I want to put the German audio track on another video that has only the Japanese audio track atm. Wouldn't it be easy to sync the German audio track of the first video with the help of both Japanese tracks? There is already a tool which does something similar for subtitles: https://github.com/tp7/Sushi
Well, sometimes it's kinda hard to sync two different languages due to different length of syllables. Maybe you should try make yourself for better quality? I had an experience with these tools you mentioned and final quality doesn't seem great.
Syncing based on audio isn't a good idea in my opinion. What you want to do is compare the video tracks and adjust the audio based on the video difference.
On the contrary, with the larger amount of tracks, the more a hefty app like PPro is the correct tool for the job.
Sync on video if possible, then on music/sfx (as those are often common to all language releases), then try overall vocal dynamics & emphasis, then lastly on actual syllabic changes, as those are the most unique to each language.
I say this having done a bunch of multi-language titles for corporate clients (incl Spanish, French, German, Chinese).
syncing an audio track to the video?
By DiodE in forum AudioReplies: 4Last Post: 13th Oct 2021, 20:49 -
Batch removal of second audio language track
By efiste2 in forum Newbie / General discussionsReplies: 2Last Post: 4th Sep 2021, 10:41 -
one audio language option vanished, in a dual audio track IN VLC mdia plyr
By jraju in forum Newbie / General discussionsReplies: 0Last Post: 28th Dec 2019, 07:43 -
Syncing Audio Tracks from DVD
By max_cady in forum AudioReplies: 0Last Post: 11th Jul 2019, 17:12 -
Searching tool that helps with syncing 2 audio language files
By landogarner in forum Authoring (DVD)Replies: 3Last Post: 20th Aug 2017, 05:39
