https://astream.hotmovies.com/streams3/055/55666/55666.ism/55666.mpd?ssauth=29275754-5...ate+%3E+350000
No pssh nor kid in mpd file.
Results 1 to 11 of 11
There is mpd in the zip, the other one I don't know is it the key?
Thank you in advance!Last edited by d9111; 18th May 2022 at 09:35.
This MPD doesn't have protection inside so there's no need of KID/PSSH. ytdlp throws out
This prolly means that the fragments are no longer located on the server, so it can't download.Code:ERROR: Did not get any data blocks ERROR: unable to download video data: [Errno 2] No such file or directory: 'srghth.m4a.part-Frag1'
[Attachment 64856 - Click to enlarge]
The mpd link can be downloaded, and it is protected after I downloaded it, so I don't understand how it is protected? What I pack in the zip is a file that I think might be the key. -
I found a solution elsewhere, thank you for the kindness to answer the question!
“To anyone who is wondering, I was able to download streaming scenes that I rented from HotMovies.com. I'm not sure if this works for all streaming scenes on the site but here's what I did:
1. Start streaming the scene in your browser, open up "Inspect Element" panel and go to the "Network" tab, then refresh the page.
2. Start playing the video and you'll see a bunch of files pop up under the "Network" tab. The .dash files are segments of the video and audio that you're streaming, but they're encrypted. To break this encryption, you will need to download two very small .dash files that are the earliest in their respective sequences and don't actually contain any video or audio data; these are the "initiator" files.
3. Now you have to download all the .dash segments of the video and audio. You can see the links for each segment pop up in the "Network" tab as the video is playing. You'll notice that the links follow a pattern . You can use Microsoft Excel to replicate this pattern and thus generate the links for all the segments.
4. Download all the segments using the links you generated. You can do this however you want; I installed the Tab Save extension in Chrome, copied a large proportion of the links, and got Tab Save to try and open all of the copied links at once.
5. Once you have all the segments downloaded, you have to concatenate all of them with the initiator as well. I used the File Joiner program for this. Just make sure that your segments are ordered correctly in File Joiner, with the initiator file always being first in the list.
6. Once you've concatenated all your video segments into one video file and all your audio segments into one audio file, you just need to put them together. I simply muxed them in MKVToolNix.”
I followed the above method successfully, it was a bit fiddly, but it played fine. -
MPD L3 download
By intheory628 in forum Video Streaming DownloadingReplies: 4Last Post: 5th Jan 2023, 11:02 -
How to download from zee5 site and download mpd link
By qasem1368 in forum Video Streaming DownloadingReplies: 7Last Post: 25th Nov 2021, 22:28 -
How to download this MPD?
By jdanielw in forum Video Streaming DownloadingReplies: 2Last Post: 14th Feb 2021, 05:55 -
Download this mpd... help
By leoglez29 in forum Video Streaming DownloadingReplies: 4Last Post: 17th Jul 2020, 23:25 -
how to download MPD
By gonto333 in forum Video Streaming DownloadingReplies: 1Last Post: 29th Jun 2020, 20:58
