i am getting .mp4 movies which are originally 1150 kbps and the file sizes are 1gb+. i want to reduce the file size and keep the same quality
i am reencoding the movies in handbrake by selecting 2-pass encoding and turbo first pass. i need to pick an avg bitrate. what is a good bitrate to pick? are 800 kbps or 850 kbps or 900 kbps ok?
i am comparing the original movie to the encoded movie. they look the same. however, if there is something faint like a small cloud in the upper right corner in the original movie then that cloud becomes a bit blurry in the encoded movie. why is handbrake making faint things blurry?
Results 1 to 11 of 11
it can happen. i want to the encoded file to have good quality and smaller size. i just want to know if the bitrates that i am using are ok
Not gonna happen,just be happy with the tiny size of the movie,any smaller and it will get worse quality.
Every time you re-encode with a lossy codec, even if you use more bitrate, you will get a loss of quality.
Every video is different. Different codecs have different abilities (you haven't indicated what codec your source is and what codec you are re-compressing with). And everybody's opinion on quality differs. It's up to you whether the quality you're getting is acceptable. There's no right answer to those questions. But to me, re-encoding just to save 20 or 30 percent in file size doesn't sound like it's worth the time and loss of quality.
That's exactly the type of artifact one expects when re-encoding with a lossy codec. -
You're arguing with some people who have forgotten more about this subject than you know.
'mp4' is just a container and you don't say what codec/format you're encoding to. If you're encoding an x264 source then x265 would be better.
Most of those videos you're talkling about may say they're from the bluray but they aren't. They're 2 generations from the bluray and you want to re encode it again. You're always going to lose quality when re encoding but what you\'re talking about will really lose it.
There's a lot more involved than just bit rate and, as mentioned, there are no "one size fits all" encoder settings. -
Waiting for the "I did it, it's smaller with better quality - bye." post.
The odds are good that you don't want to go below average 1150 kbps, if the person that transcoded those files could have gone lower they would have. What you need is some high-quality files to start out with. If you have the right DVD/Bluray reader/burner in your computer you could use http://www.makemkv.com/ to rip some movies. But that could take a while, you can get perfectly legal Demo files from https://4kmedia.org/ to play around with. About settings in handbrake, lighterra.com, has some settings in a zip file you can use, you will find it in their article Video Encoding Settings
for H.264 Excellence -
Seems to me your issue has more to do with filesize than with that bitrate.
So, with knowledge of the universal bitrate formula (Filesize = Bitrate * Running time), the answer is simple: cut your clip in 1/2 and just keep the 1st half!
No need to ever have a file go over 1 GB agai...
Scott -
@cns00, you may want to learn how to use compression quality metrics like PSNR. I don't think that reducing bitrate from 1150 kbit/s to 900 kbit/s is worthwhile unless you need to squeeze a video onto a particular media, in which case the output bitrate is a given, and you need to find a combination of encoder type and encoder parameters to incur the least damage to the video.
Any way to reduce this noise?
By natfunk71 in forum Capturing and VCRReplies: 1Last Post: 8th May 2020, 02:32 -
How do you reduce color noise in Staxrip?
By SomeoneNeutral in forum RestorationReplies: 6Last Post: 31st Aug 2019, 12:47 -
How to maintain bitrate when editing, plus not need to reduce the FPS??
By Apollo89x in forum EditingReplies: 14Last Post: 30th Jun 2018, 07:12 -
reduce line spacing
By SUWII in forum SubtitleReplies: 5Last Post: 8th Nov 2017, 23:49 -
How to reside/reduce VOB files?
By yoshi10usa in forum Newbie / General discussionsReplies: 3Last Post: 18th May 2017, 15:38
