Results 1 to 29 of 29
  1. I have a old one and can't use the HDMI port for TV channels or blu-ray. I can use Google Chromecast ultra for pictures. I have not try to stream any. but it only gives a black screen when trying TV or bluray. I have checked the HDMI cable and it works on another tv
    Mar 2008
    Depending on the vintage of the tv it may not have HDCP. If it's not there modern devices
    may not stream to it
  3. I tried to stream from my Chromebook and it worked but it lagged from the usual cast menu on the Chromebook. So ii guess the TV can show video trough HDMI. Is there any way to stream trough Chromebook without using internet or wifi? I want to use the Chromecast ultra.
  4. I can't understand why the screen only went black when using HDMI for bluray or TV box. I have tried both HDMI options on the TV.
    Aug 2006
    Someone already mentioned HDCP as a possible cause of this problem. Blu-ray players and many TV boxes apply HDCP to their video output for copy-protected content delivered using HDMI. Your TV dates from 2005 and might be so old that HDCP handshaking doesn't work as it should when it is connected to newer devices that use recent versions of HDMI and HDCP.
  6. Originally Posted by OldSchool297 View Post
    Devices that require HDCP encryption will not send a picture to an HDMI display that doesn't support it.
    https://en.wikipedia.org/wiki/High-bandwidth_Digital_Content_Protection
    Look for an HDMI splitter that strips HDCP. You should be able to find one for about US$20.
    Aug 2006
    An Internet connection is necessary to access streaming services. I think it is possible to cast video from another device to a Chromecast Ultra without using Wi-Fi. See https://www.the-tech-addict.com/how-to-use-chromecast-without-wifi-and-internet/
  8. I wanted to stream from my Chromebook downloads to my Chromecast ultra. But i don't find the cast button without wifi. There is also a PC card slot on this retro TV. I saw it could record live TV. How big can the cards be for this? I only have a Canon multimedia card MMC-16M 16mb.
  9. Originally Posted by OldSchool297 View Post
    Thanks for the help. I didn't found info in the manual by a quick look https://www.google.com/url?sa=t&source=web&rct=j&url=https://www.manualslib.com/manual...dCZ9SiQ6G5uUCG
    The manual shows an HDCP decrypter module on page 133.
    Make sure your devices are set to output a format the TV supports. For example, 1080i, not 1080p. Many early HDTVs did not support 1080p input.
  10. Thanks i will try. So i guess this vintage TV can handle hdcp after all? I seen MMC cards can be found in 512gb max. How much can this TV handle?
    Aug 2006
    Unfortunately, even if the TV supports HDCP that doesn't guarantee success. Until recently I had a 2015 HDTV hooked up to a 2009 cable box via HDMI. The TV wouldn't display a picture even though the same cable box and HDMI cable worked perfectly in the past with a 2008 HDTV connected via HDMI. Installing a splitter that stripped HDCP fixed the problem. I didn't need the splitter anymore after I replaced the old cable box with the current model from my service provider last month
    Good idea. The TV's manual says that the TV supports 720p and 1080i but doesn't mention 1080p.
  12. I tried a Motorola VIP 1910-9 and it showed the start picture and meny. I don't have a TV card for it so i could not try. I guess i need a adapter to get my other things work in HDMI.
  13. Originally Posted by OldSchool297 View Post
    Yes. But beware that not all splitters can strip HDCP. By the HDMI license agreement they aren't supposed to. So you have to find one from a shady manufacturer.
  14. Thanks. Any examples?
  15. I don't know what's available now.
  16. I solved the problem with a new hdmi cable. The pictures went perfect on this old TV. I even got a old blu-ray player Samsung BD E5300 to work. I got the HDMI concact lost when i should remove it from the other TV. So i figured out it could have been broken before.
  17. This Tv can have max 1gb sdcard. What type of card is it? I can't find by google.
  18. It's hard to find such small flash memory cards these days. Here's one example:
    https://www.amazon.com/AlphX-Innovations-1gb-Card-pack/dp/B0842YS4CP/
    But the TV's built in media player probably won't play modern A/V files. According to the manual it only plays "MPEG4" video.
    https://www.manua.ls/panasonic/th-42pv500e/manual
    That most likely means MPEG 4 part 2 -- like Divx or Xvid videos. And probably limited to SD resolutions.
  19. Thank you i will look for them. Is it SDHC card type? I use this as a computer screen to a Dell T3500 vintage computer with a Nvidia Quadro Fx 5300 256mb card. It is good to play videos smooth. I guess the tv screen only can go to 1024? Is it the same when playing videos over Vga?
    I must have been lucky to be able to play HD video on this old computer? I got hold of a high performance vintage computer from 2010 Dell T3500 with 24GB of ram that i am very pleased with, when you don't play games it is nearly impossible to use all. A regular phone uses between 2 or 3gb. With a GDDR3 Nvidia Quadro Fx 5300 graphic card on 256mb that costed 1600dollars back in 2006. GDDR3 plays video in a better smoth way and uses less power. A standard 1080p video when playing in Vlc only use 4-7% of the cpu. And the highest video avaible in 120fps only uses 10% of the cpu. 4k is the same. And the the graphic card is from 2006. It has a Intel® Xeon® Processor E5645. 12M Cache, 2.40 GHz, 5.86 GT/s Intel® QPI. It must be a special computer. Were to find 120fps videos or in 8k? I tried in Youtube but aren't sure they are real 120fps or 8k. I am surprised this old computer can handle this with only 10% cpu usage.
  20. Originally Posted by OldSchool297 View Post
    SDHC is higher capacity SD. SDHC cards won't work in an old device that only supports SD. SDXC and SDUC are even newer and larger -- and will not work in old SD devices.
    https://en.wikipedia.org/wiki/Sdhc
    https://vishveshtech.blogspot.com/2014/09/how-to-choose-correct-memory-card.html
    Aug 2006
    Regardless of the resolution and framerate listed in a video's description, YouTube normally streams video at the best quality that both your Internet service and display device support. If you want to try playing an 8K video, you probably need to use a video downloader such as FireDM-GUI to obtain one as a file from YouTube or a website that hosts free demo files.
    4K videos and 8K videos are likely to be encoded using H265, VP9, or AV1. My 2021 Tiger Lake laptop can play those kinds of 8K 30 fps videos easily using its iGPU's Intel QuickSync video decoding. However, it is very unlikely that your ancient computer from 2006 can decode them in real time using its CPU or GPU and software decoders.
  22. I've seen several youtube videos with 8K and 120 fps in the title. But yt-dlp only shows up to 8K at 60 fps for those videos. For example:
    "8K VIDEOS | World 8K Videos HDR UltraHD (120 FPS) | Sony Demo"
    https://www.youtube.com/watch?v=WjoplqS1u18
    [info] Available formats for WjoplqS1u18:
    ID  EXT   RESOLUTION FPS │   FILESIZE    TBR PROTO │ VCODEC           VBR ACODEC      ABR     ASR MORE INFO
    sb2 mhtml 48x27          │                   mhtml │ images                                       storyboard
    sb1 mhtml 80x45          │                   mhtml │ images                                       storyboard
    sb0 mhtml 160x90         │                   mhtml │ images                                       storyboard
    139 m4a   audio only     │    1.82MiB    48k https │ audio only           mp4a.40.5   48k 22050Hz low, m4a_dash
    249 webm  audio only     │    1.90MiB    51k https │ audio only           opus        51k 48000Hz low, webm_dash
    250 webm  audio only     │    2.52MiB    67k https │ audio only           opus        67k 48000Hz low, webm_dash
    140 m4a   audio only     │    4.82MiB   129k https │ audio only           mp4a.40.2  129k 44100Hz medium, m4a_dash
    251 webm  audio only     │    4.97MiB   133k https │ audio only           opus       133k 48000Hz medium, webm_dash
    17  3gp   176x144      8 │    2.91MiB    78k https │ mp4v.20.3        78k mp4a.40.2    0k 22050Hz 144p
    394 mp4   256x144     30 │    2.36MiB    63k https │ av01.0.00M.08    63k video only              144p, mp4_dash
    160 mp4   256x144     30 │    1.79MiB    48k https │ avc1.4d400c      48k video only              144p, mp4_dash
    278 webm  256x144     30 │    2.89MiB    77k https │ vp9              77k video only              144p, webm_dash
    395 mp4   426x240     30 │    4.15MiB   111k https │ av01.0.00M.08   111k video only              240p, mp4_dash
    133 mp4   426x240     30 │    4.20MiB   112k https │ avc1.4d4015     112k video only              240p, mp4_dash
    242 webm  426x240     30 │    4.95MiB   132k https │ vp9             132k video only              240p, webm_dash
    396 mp4   640x360     30 │    8.94MiB   240k https │ av01.0.01M.08   240k video only              360p, mp4_dash
    134 mp4   640x360     30 │    9.66MiB   259k https │ avc1.4d401e     259k video only              360p, mp4_dash
    18  mp4   640x360     30 │ ~ 14.80MiB   388k https │ avc1.42001E     388k mp4a.40.2    0k 44100Hz 360p
    243 webm  640x360     30 │   11.15MiB   299k https │ vp9             299k video only              360p, webm_dash
    397 mp4   854x480     30 │   17.10MiB   459k https │ av01.0.04M.08   459k video only              480p, mp4_dash
    135 mp4   854x480     30 │   16.86MiB   453k https │ avc1.4d401f     453k video only              480p, mp4_dash
    244 webm  854x480     30 │   21.04MiB   565k https │ vp9             565k video only              480p, webm_dash
    136 mp4   1280x720    30 │   55.20MiB  1483k https │ avc1.4d401f    1483k video only              720p, THROTTLED, mp4_dash
    247 webm  1280x720    30 │   41.18MiB  1106k https │ vp9            1106k video only              720p, THROTTLED, webm_dash
    22  mp4   1280x720    30 │ ~ 61.41MiB  1612k https │ avc1.64001F    1612k mp4a.40.2    0k 44100Hz 720p
    398 mp4   1280x720    60 │   51.83MiB  1392k https │ av01.0.08M.08  1392k video only              720p60, mp4_dash
    298 mp4   1280x720    60 │   91.04MiB  2446k https │ avc1.4d4020    2446k video only              720p60, mp4_dash
    302 webm  1280x720    60 │   67.97MiB  1826k https │ vp9            1826k video only              720p60, webm_dash
    399 mp4   1920x1080   60 │  100.74MiB  2707k https │ av01.0.09M.08  2707k video only              1080p60, mp4_dash
    299 mp4   1920x1080   60 │  173.73MiB  4669k https │ avc1.64002a    4669k video only              1080p60, mp4_dash
    303 webm  1920x1080   60 │  123.94MiB  3330k https │ vp9            3330k video only              1080p60, webm_dash
    400 mp4   2560x1440   60 │  252.04MiB  6773k https │ av01.0.12M.08  6773k video only              1440p60, mp4_dash
    308 webm  2560x1440   60 │  365.02MiB  9810k https │ vp9            9810k video only              1440p60, webm_dash
    401 mp4   3840x2160   60 │  506.08MiB 13601k https │ av01.0.13M.08 13601k video only              2160p60, mp4_dash
    315 webm  3840x2160   60 │  845.49MiB 22722k https │ vp9           22722k video only              2160p60, webm_dash
    571 mp4   7680x4320   60 │    1.05GiB 28821k https │ av01.0.17M.08 28821k video only              4320p60, mp4_dash
    In this case the comments indicate it was actually shot at 4K and upscaled.
  23. Member
    Aug 2006
    The TV OldOchool297 is using doesn't support HD video at 120 fps anyway. Even if it did, the VGA and DVI connections on his video card can't provide HD video output at 120 fps.
    Just for fun, I downloaded the 8K 60fps AV1 video from https://www.youtube.com/watch?v=WjoplqS1u18 My Tiger Lake laptop could play that too. I often wish Intel had released a Tiger Lake Desktop processor too.
  24. I tried to play a Top Gun Maverick 2160p x265 with bit rate 6391kb/s. 23.976fps. 3840/2024. I have had my computer on for a week and the Vlc player played it with between 15-28% cpu usage. This vintage computer plays videos pretty good. 12 years old and a graphic card from 2006.
  25. And so can a $20 media player.
  26. Member
    Aug 2006
    I'll have to see if my desktop with an Intel i5 10400, which is only a mid-range processor by today's standards, can do the same without using Quick Sync video decoding. It has 6 cores and 12 threads with a base clock speed of 2.67 GHz and a boost clock speed of 4.3 GHz, which are somewhat better specs than your Xenon has.
  27. Originally Posted by usually_quiet View Post
    2160p x265
    Easily. My older 8 core 16 thread Intel CPU can do it with 10 to 15 percent CPU usage (with integrated graphics).
