This looks amazing
Is there anything that could be done to the bluray source to achieve this kind of look in the terms of outlines, not black levels
Results 31 to 36 of 36
Is it possible to redo the colours or something
the Blu-ray:
and the DVD:
(increase gamma on both to 1.5)
you can see that the only issue is the Y (= luma) field, so in theory if you can rid of the ghosting,
one could do the following (in an NLE or Avisynth/Vapoursynth):- load both sources
- crop and resize them to the same size
- sync them
- split them into their YUV components
- take the Y-component of the DVD replace the Y-component of the Blu-ray with it.
- do some additional filtering/cleaning on the Y-component
So it would probably say: Yes, it's possible, but I doubt someone is willing to spend the time and effort to do it since I do not thing it can be done without a lot of manual adjusting.
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini -
There are plenty of good looking scenes on the bd. I am going to send them later
Okay, then you only would have to do the procedure for the scenes that have issues.
So like load both sources with two different filterings applied and combine them
Yes.
Need help with strong halos, color bleed (EP16, Neon Genesis Evangelion)
By pwnsweet in forum EditingReplies: 13Last Post: 21st May 2022, 01:41 -
Restoring telecined video
By semel1 in forum Newbie / General discussionsReplies: 13Last Post: 2nd Feb 2021, 09:57 -
Restoring really old cartoons
By Fleischacker in forum RestorationReplies: 7Last Post: 13th Nov 2020, 22:23 -
A 5 episode TV series but one episode will not download
By pooksahib in forum Video Streaming DownloadingReplies: 3Last Post: 27th Apr 2018, 06:31 -
8mm restoring
By Digital85 in forum RestorationReplies: 12Last Post: 18th Mar 2018, 04:20
