  1. Anonymous
    Guest
    Hello
    I have a problem with the length of a video in Losslesscut
    I want to cut a few seconds at the beginning and end of a movie fragment, but what happens is that when it exports, it exports with the same duration (24 seconds), when it should be 15 seconds.
    This fragment I pulled it for the first time from the movie (which is 24 seconds long) but now I need to trim it without having extra seconds.
    The LLC file and the movie are all in their source folder.
    What could it be?
    Mar 2008
    According to the release notes the program implemented an experimental "smart", frame accurate cut.
    Without this working, you will not be able to do the cut you want with this typical long GOP video
    Other alternatives are Tmpgenc smart renderer, or VideoRedo
  3. Anonymous
    Guest
    Thank you for your response and help davexnet!
