Hello,
I have this old movie encoded in DIVX5 that does not play on media players but plays well on a PC. More importantly the aspect ratio is wrongly encoded 4:3 and I need to stretch the image completely and fill my 16/9 screen to reestablish the correct proportions.
How can I convert this file to play well with the correct aspect ratio on a media player?
Results 1 to 15 of 15
Well it6 is quite easy to resize a video and re-encode to a more compatable codec. Whether a video using quite a legacy codec is up to the task is questionable.
What I suggest is you install avidemux (you will use it later for the task), use A/B markers and select 20-30 secs of the video. Choose copy for video and audio and output format same as what you currently have. Save the video and upload it here as an attachment. We can then have a 'play' with it just to see what is possible.
Just do not expect miracles. -
That's rather unusual. Most media players can play DIVX5 and XVID. Use MediaInfo (text mode) to examine the video, post the result here. It's likely there's something else causing the problem. What does "does not play" mean? Does the player see the video? When you select it does it even try to play it? Do you get any picture at all? Does it get corrupt at times? A simple remux to AVI might result in a video that plays on your player. Some older players can only play DIVX/XVID at less than or equal to 720x576. And only in an AVI container.
That can be done without reencoding with Mpeg4Modifier. -
Mpeg4modifier did the job of correcting the aspect ratio beautifully.
Now remains only the playability on media players (Dune, eGreat, Zidoo, etc....). The picture freezes but the sound keeps running.
Here is the Mediainfo output:
General
Complete name : z:\Trash\Le Champion (1979).avi
Format : AVI
File size : 768 MiB
Duration : 2 h 2 min
Overall bit rate : 876 kb/s
Video
Format : MPEG-4 Visual
Format settings : BVOP1
Format settings, BVOP : 1
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Muxing mode : Packed bitstream
Codec ID : DX50
Codec ID/Hint : DivX 5
Bit rate : 790 kb/s
Nominal bit rate : 4 000 kb/s
Width : 480 pixels
Height : 352 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.187
Stream size : 693 MiB (90%)
Title : Video
Writing library : DivX 5.2.1 Alpha (UTC 2004-09-08)
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Format settings : Joint stereo / MS Stereo
Codec ID : 55
Codec ID/Hint : MP3
Bit rate mode : Constant
Bit rate : 32.0 kb/s
Channel(s) : 2 channels
Sampling rate : 44.1 kHz
Stream size : 64.8 MiB (8%)
Alignment : Aligned on interleaves
Interleave, duration : 26 ms (0.65 video frame)
Interleave, preload duration : 234 ms
Title : Audio
Writing library : LAME3.92 -
The two features that often cause problems (QPel and GMC) aren't used in that video. The frame dimensions (480x352) are OK but the bitrate is pretty high that frame size. A remux with AviDemux or VirtualDub might help. What player(s) are you using?
I don't have it at hand but it's a Probox android box. Pretty standard player.
Hi, if ou wnat to change the aspect ratio from 4:3 to 16:9 you can also you use ffmpeg :
But I would recommand the other tools mentionned in the previous posts.Code:ffmpeg -i input.avi -vcodec copy -acodec copy -aspect 16:9 output.avi
Alos, something you can try is to change the Fourcc of your video with AVI FourCC Code Changer. Actualy it is DX50 (for DivX 5.0) , change to XVID (in order to use XviD which more players are compatible).
Like this you won't have to re-encode.
Best regardsLast edited by Hunk91; 13th May 2022 at 09:36.
This is for my ailing mother who wishes to see that in French.
So I just thought about a more ambitious task.
I just found a much better version of the movie in 1080p but the audio in is English.
Would that be feasible to extract the audio from my AVI file which is in 25fps and mux it within the mkv 1080p 23.976fps version and of course achieve perfect sync? -
Ok now. I have an MP3 audio file and an MKV file for the video. I used MKVtoolnix to mix them together but I end up with the audio track being 1.5s too early for the whole length of the movie. How do I remedy to that? I only have to delay the whole audio track by 1.5s.
MKVToolNixGUI lets you specify an audio delay. After adding your sources highlight the audio track in the lower left pane. Set the delay it to 1500 ms.
Ok. So you, if I read you right, have abandoned the idea of using the original video.
Pretty sensible plan given the small frame size which was in my mind in the initial reply. As for the AR that appears to be screwed up regardless. And I doubt if it was 16:9 in the first place. But without seeing the actual video who knows. -
All these tasks (changing aspect ratio, extracting audio and changing length and pitch, muxing to another video track in another container and much more) can all be done with one tool: clever FFmpeg-GUI.
Any file with "Packed bitstream " is problematic on the Zidoo in my experience. I used Mpeg4Modifier to unpack - voila!
How to stretch subtitle by runtime ?
By DonSeenu in forum SubtitleReplies: 4Last Post: 12th Nov 2025, 19:09 -
ffmpeg combine videos, stretch the lower quality
By kucing in forum Newbie / General discussionsReplies: 6Last Post: 25th Mar 2022, 21:43 -
How to freely audio stretch ?
By DonSeenu in forum AudioReplies: 9Last Post: 12th Feb 2021, 22:10 -
VirtualDub 2 pane layout, no stretch?
By Goggen240 in forum Newbie / General discussionsReplies: 3Last Post: 28th Sep 2019, 08:56 -
Why does Youtube player stretch MPEG1/2 video not H.264?
By parumaru in forum Video Streaming DownloadingReplies: 14Last Post: 26th Jun 2017, 15:59
