Maybe need something else for decrypt files?
manifest.mpd below:
HTML Code:<?xml version="1.0"?> <MPD xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="urn:mpeg:dash:schema:mpd:2011" xsi:schemaLocation="urn:mpeg:dash:schema:mpd:2011 http://standards.iso.org/ittf/PubliclyAvailableStandards/MPEG-DASH_schema_files/DASH-MPD.xsd" type="static" mediaPresentationDuration="PT3896.920S" minBufferTime="PT4S" profiles="urn:mpeg:dash:profile:isoff-main:2011"> <Period> <AdaptationSet id="1" segmentAlignment="true" maxWidth="1280" maxHeight="720" maxFrameRate="25"> <ContentProtection schemeIdUri="urn:mpeg:dash:mp4protection:2011" value="cenc"/> <ContentProtection xmlns:cenc="urn:mpeg:cenc:2013" schemeIdUri="urn:uuid:1077efec-c0b2-4d02-ace3-3c1e52e2fb4b" cenc:default_KID="b9221d5a-d918-f6e5-2eb3-ada7d6d66439"> <cenc:pssh>AAAANHBzc2gBAAAAEHfv7MCyTQKs4zweUuL7SwAAAAG5Ih1a2Rj25S6zrafW1mQ5AAAAAA==</cenc:pssh> </ContentProtection> <SegmentTemplate timescale="1000" media="https://46401c0a-3c5a-44eb-ae1b-9ac6db282186.selcdn.net/316f5420eafbc88abddc5277f65b2c86/00001634-372b-48de-ba1f-411c1f346de7.json/segment-$Number$-$RepresentationID$.m4s" initialization="https://46401c0a-3c5a-44eb-ae1b-9ac6db282186.selcdn.net/316f5420eafbc88abddc5277f65b2c86/00001634-372b-48de-ba1f-411c1f346de7.json/init-$RepresentationID$.mp4" startNumber="1"> <SegmentTimeline> <S d="4000" r="973"/> <S d="920"/> </SegmentTimeline> </SegmentTemplate> <Representation id="f1-v1-x3" mimeType="video/mp4" codecs="avc1.64001f" width="1280" height="720" frameRate="25" sar="1:1" startWithSAP="1" bandwidth="2110887"> </Representation> <Representation id="f2-v1-x3" mimeType="video/mp4" codecs="avc1.64001e" width="852" height="480" frameRate="25" sar="1:1" startWithSAP="1" bandwidth="1206309"> </Representation> <Representation id="f3-v1-x3" mimeType="video/mp4" codecs="avc1.64001e" width="640" height="360" frameRate="25" sar="1:1" startWithSAP="1" bandwidth="603312"> </Representation> </AdaptationSet> <AdaptationSet id="2" segmentAlignment="true"> <AudioChannelConfiguration schemeIdUri="urn:mpeg:dash:23003:3:audio_channel_configuration:2011" value="1"/> <ContentProtection schemeIdUri="urn:mpeg:dash:mp4protection:2011" value="cenc"/> <ContentProtection xmlns:cenc="urn:mpeg:cenc:2013" schemeIdUri="urn:uuid:1077efec-c0b2-4d02-ace3-3c1e52e2fb4b" cenc:default_KID="b9221d5a-d918-f6e5-2eb3-ada7d6d66439"> <cenc:pssh>AAAANHBzc2gBAAAAEHfv7MCyTQKs4zweUuL7SwAAAAG5Ih1a2Rj25S6zrafW1mQ5AAAAAA==</cenc:pssh> </ContentProtection> <SegmentTemplate timescale="1000" media="https://46401c0a-3c5a-44eb-ae1b-9ac6db282186.selcdn.net/316f5420eafbc88abddc5277f65b2c86/69f739fd-9012-4a80_bc74-d3aca7af8ce4.json/segment-$Number$-$RepresentationID$.m4s" initialization="https://46401c0a-3c5a-44eb-ae1b-9ac6db282186.selcdn.net/316f5420eafbc88abddc5277f65b2c86/69f739fd-9012-4a80_bc74-d3aca7af8ce4.json/init-$RepresentationID$.mp4" startNumber="1"> <SegmentTimeline> <S d="4000" r="973"/> <S d="981"/> </SegmentTimeline> </SegmentTemplate> <Representation id="f1-a1-x3" mimeType="audio/mp4" codecs="mp4a.40.2" audioSamplingRate="48000" startWithSAP="1" bandwidth="192000"> </Representation> </AdaptationSet> </Period> </MPD>
Results 211 to 240 of 276
Good afternoon, everyone!
there is such a problem, the organization promised access to the materials forever, and then a letter came that access would be available until August
Therefore, I decided to save the video locally
According to the recipe from message No. 38, it does not work.
I was able to findfound the address of the streamCode:media.m3u8
can you tell me where to dig further to get a result?Code:https://edge-msk-2.kinescopecdn.net/==c8b==052549/videos/6=2f6==83aa53dd/assets/eb====2a68ace46==43/47===36/55===034/1080p.mp4
in thefile, I see all the parts that the video is divided intoCode:media.m3u8
I have the parameters:
Code:kci kinescope_project_id sign
I see that the video is divided into 349 parts
Thank you very much! -
You do! Noobs starter kit is built for you.
Noob Starter Pack. Just download every Widevine mpd! Not kidding!.
https://files.videohelp.com/u/301890/hellyes6.zip -
what do you mean by a "normal" address?
[Attachment 79992 - Click to enlarge]
and I see this stream from the site I need -
https://unicaster.ru/grabim-video-s-kinescope-io/
I found another option to save videos from the site -
Deleted.
You've got to be joking!! You are, right?? Aren't you?? You say you need to find the pssh? And if there is no pssh, what do you do then? But then you say you need to paste a cURL of the license? And then you have to go to curlconverter.com to paste the curl again to get headers? Why? They are already in the first curl that you pasted. And finally back to where you pasted the pssh. and it only gives you keys? So you then you need to download bits of video and audio and apply the keys to decrypt and then join the bits? And you recommend that? Which planet are you from, friend?
With the noob starter pack you provide the mpd (No searching through it for pssh and selecting the wrong one, it finds or makes one). And all you do the is paste the license cURL and the video name. And the script - hell3.py - obtains the pssh, get keys and downloads a playable video. Simples https://files.videohelp.com/u/301890/hellyes.zip 438 downloads by users.Noob Starter Pack. Just download every Widevine mpd! Not kidding!.
maybe someone can help with my question?
I was able to download the audio track separately
, I also found an m3u8 file with video track segments
, but how do I download these video segments? -
Key for HRT2 Croatia?
Thanks in advance.https://hrti.hrt.hr/live/tv
https://cdn1oiv.akamaized.net/hrtliveorigin/hrt2e2.smil/1/manifest.mpd
https://lic.drmtoday.com/license-proxy-widevine/cenc/
kid c16c144466603f00bf91cc5b80ed3096 -
I couldn't get auth for that channel :
HTML Code:{'ErrorCode': 601, 'ErrorDescription': 'NOT_ENTITLED', 'Result': {'Authorized': False, 'DrmId': None, 'SessionId': None}}
[Attachment 80403 - Click to enlarge] -
kid/key for sky sports racing?
https://linear010-gb-dash1-prd-ak.cdn.skycdp.com/016a/Content/DASH_003_720_120/Live/ch...nifest_720.mpd
AAAAOHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAABgSEAAFWN HGPoyN0eNF6UTWAohI49yVmwY= -
Does anyone have the key? Thanks in advance, as always.
https://fsly.stream.peacocktv.com/Content/CMAF_OL1-CTR-4s/Live/channel(usa-east)/master.mpd
AAAAV3Bzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAADcIARIQkb 8tgbnhNwGsZnkVZBEhuBoLYnV5ZHJta2V5b3MiEJG/LYG54TcBrGZ5FWQRIbgqAkhE
KID 91bf2d81b9e13701ac667915641121b8 KEY ? -
The URL has changed. What headers do I need? Did you use any proxy? I get the message "{"code":400,"error":true,"message":"Failed to get license: 403 "}"
https://cdn1oiv.akamaized.net/hrtliveorigin/hrt2e3.smil/1/manifest.mpd
kid bc01006c0e4b39eeadf359f4178124ca -
I used my new Script
It's just a simple copy-and-paste of the 'Copy as fetch'. No custom implementation needed.Code:[INFO] Parsing input... [INFO] Retrieving challenge... [INFO] Obtaining pssh... [INFO] Sending request... [INFO] Retrieving license... [INFO] Parsing license... [INFO] --key edd08df18e523831bb1849eb897f20e0:5d936f87fd0aab2aba6578d1342d5041
Bypass HMACs, One-time-tokens and Lic.Wrapping: https://github.com/DevLARLEY/WidevineProxy2
Help Downloading video
By gilbertati in forum Video Streaming DownloadingReplies: 4Last Post: 27th Mar 2021, 16:39 -
help downloading this video
By Lionking in forum Video Streaming DownloadingReplies: 7Last Post: 1st Dec 2020, 23:04 -
Help downloading a video
By mainblue01 in forum Video Streaming DownloadingReplies: 2Last Post: 1st Aug 2019, 17:15 -
downloading subtitles that are not part of video and are overlayed on video
By 3dsmaxed in forum Newbie / General discussionsReplies: 1Last Post: 7th May 2019, 03:41 -
Help me out downloading this video
By smithmike in forum Video Streaming DownloadingReplies: 3Last Post: 5th Oct 2017, 20:14
