Results 181 to 210 of 276
no video URL then everyone cant help you
read the rules
https://forum.videohelp.com/threads/404993-Please-ONLY-ask-for-help-videos-that-everyo...ere-is-my-post -
And you will learn how to quote the messages of others!
The link is closed, you will not be able to access it. Only such data is available:
Code:"videoId": "player_c7db6f3b-d54f-4ed4-bad1-3cebf1726b4c "url": "https://kinescope.io/embed/qFoSYGkEKhWoueAK8E1qHA "referrer": "https://glebkornilov.ru/
Full data from the player's system log:
PHP Code:{
"clientId": "7ac40466-e438-4daf-b5af-67cff3e059fb",
"playerId": "player_c7db6f3b-d54f-4ed4-bad1-3cebf1726b4c",
"containerId": "player_c7db6f3b-d54f-4ed4-bad1-3cebf1726b4c",
"url": "https://kinescope.io/embed/qFoSYGkEKhWoueAK8E1qHA",
"options": {
"playlist": [
"sources": {
"src": "https://kinescope.io/c7db6f3b-d54f-4ed4-bad1-3cebf1726b4c/master.m3u8?expires=1704638364&kinescope_project_id=6a57f91a-ad87-47ac-a336-9e6886e0f273&sign=85b657a6f2730d92eecfa7186d142caa&token="
"shakadash": {
"src": "https://kinescope.io/c7db6f3b-d54f-4ed4-bad1-3cebf1726b4c/master.mpd?expires=1704638364&kinescope_project_id=6a57f91a-ad87-47ac-a336-9e6886e0f273&sign=85b657a6f2730d92eecfa7186d142caa"
"tools": [],
"drm": {
"auth": null,
"clearkey": null,
"fairplay": {
"certificateUrl": "https://license.kinescope.io/v1/vod/c7db6f3b-d54f-4ed4-bad1-3cebf1726b4c/certificate/fairplay?token=",
"licenseUrl": "https://license.kinescope.io/v1/vod/c7db6f3b-d54f-4ed4-bad1-3cebf1726b4c/acquire/fairplay?token="
"widevine": {
"licenseUrl": "https://license.kinescope.io/v1/vod/c7db6f3b-d54f-4ed4-bad1-3cebf1726b4c/acquire/widevine?token="
"sampleAes": false
"shakadash": {
"quality": 1080,
"drm": {
"auth": null,
"clearkey": null,
"fairplay": {
"widevine": {
"sampleAes": false
"meta": {
"folderId": "6a57f91a-ad87-47ac-a336-9e6886e0f273",
"projectId": "6a57f91a-ad87-47ac-a336-9e6886e0f273",
"workspaceId": "a2773dba-d890-4ddc-b7bf-3ac64c4e8a65",
"type": "vod"
Have you forgotten how to read? I wrote that the link is not available, as this is a closed access to the video course! I have attached all the data above.
Why is the video being downloaded with a corrupted video? I attached the screenshot above in the post, it shows all the videos like this.
[Attachment 76091 - Click to enlarge]Last edited by L4D2; 7th Jan 2024 at 09:56. Reason: add img
Я бы мог ответить Вам по-русски, но боюсь, что Вы не только английский не понимаете.
PSSH:
License URL:Code:AAAAbnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAAE4SIDVhNTU3NTYzNzY2NTc0Mzg0ZTVmNzE3OTMxNTY1NTNkIiRjN2RiNmYzYi1kNTRmLTRlZDQtYmFkMS0zY2ViZjE3MjZiNGNI88aJmwY=
Key:Code:https://license.kinescope.io/v1/vod/c7db6f3b-d54f-4ed4-bad1-3cebf1726b4c/acquire/widevine
Grab with:Code:5a557563766574384e5f71793156553d:6f4e796d7979365479674b4e6d50383d
Code:n_m3u8dl-re "https://kinescope.io/c7db6f3b-d54f-4ed4-bad1-3cebf1726b4c/master.mpd?expires=1704638364&kinescope_project_id=6a57f91a-ad87-47ac-a336-9e6886e0f273&sign=85b657a6f2730d92eecfa7186d142caa" --key 5a557563766574384e5f71793156553d:6f4e796d7979365479674b4e6d50383d
Hello! I have some problems with downloading. The process stopps at 99%. Please tell me how can I solve this problem?
[Attachment 76524 - Click to enlarge] -
Not sure then, server might be limiting your IP or something. Here's your file btw: https://gofile.io/d/yoOweB
Thank you for your help! I have done it! It was probably some kind of glitch.
Hi, how did you got Key from PSSH?
I've been reading the forum all night, found several themes pinned about it, but just could not get the right way to convert it. Could you please help me with that?
Here is what I've done:
- I have license URL for kinescope video
- I managed to get PSSH and mpd file
- I installed python scrypt from this topic as of October 2023: https://forum.videohelp.com/threads/404994-Decryption-and-the-Temple-of-Doom
This is where I failed cause I don't know where to get the blob and WVD file. I'm not even sure if I need to. I tried to convert PSSH here: https://tools.axinom.com/decoders/PsshBox and got those errors. I need to understand how to convert PSSH to key, I have many videos which are very much needed to me.
[Attachment 76664 - Click to enlarge]
Here is that PSSH I got please teach me:
Code:AAAAbnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAAE4SIDMzNjg0NjY1MzY2Nzc2NzQ2MTcwNjkzMTQ5NGU0MTNkIiQ4YWFhNzBmYS05MjRlLTQxY2UtYmRiZi1jYmZmNjZlNDZiMTZI88aJmwY=
If you're trying to download from kinescope as well, it's very basic, just input PSSH and license URL here (no headers needed): https://cdrm-project.com/
You don't even need to dump your own CDM or install Python. -
Happy 2024 everyone!
I am trying to download this: https://app.a24films.com/player/324
I got this m3u8: https://manifest.prod.boltdns.net/manifest/v1/hls/v4/aes128/6276845754001/7bbe9249-dce...caGuBO2QsIzP2A
Im using yt-dlp but I get "ERROR: unable to download video data: HTTP Error 401: Unauthorized"
Thanks in advance for any solutions -
Hi, I hope anybody can help me with download some similar videos (I have many videos which are needed to me). I don't understand how to get PSSH.
I tried to download by N_m3u8DL-RE.exe. No success.
>N_m3u8DL-RE.exe --key 75395a425350585748325a646e73673d:6170704e6b7864645 f4544327a62493d 1.mpd
20:37:57.293 INFO : Loading URL: 1.mpd
20:37:57.297 INFO : Content Matched: Dynamic Adaptive Streaming over HTTP
20:37:57.298 INFO : Parsing streams...
20:37:57.315 INFO : Extracted, there are 5 streams, with 4 basic streams, 1 audio streams, 0 subtitle streams
20:37:57.315 INFO : Vid *CENC 1920x1080 | 4475 Kbps |b16228e2-bf09-4df9-a75e-daf819f67dce | avc1.640028 | 282 Segments | ~18m48s
20:37:57.316 INFO : Vid *CENC 1280x720 | 3733 Kbps |a713f775-710f-4474-9727-d632dedca1e2 | avc1.4D401F | 282 Segments | ~18m48s
20:37:57.316 INFO : Vid *CENC 852x480 | 2427 Kbps |275ef863-738c-44f4-bb9a-16dbb0df7c48 | avc1.4D401F | 282 Segments | ~18m48s
20:37:57.316 INFO : Vid *CENC 640x360 | 1420 Kbps |7f0c9113-ab1d-47b9-8699-0072c5e6750a | avc1.4D401E | 282 Segments | ~18m48s
20:37:57.317 INFO : Aud *CENC ff833859-db5f-442c-b155-660fe63484cb | 130 Kbps |mp4a.40.2 | en | 282 Segments | ~18m48s
20:37:57.317 ERROR : Cannot show selection prompt since the current terminal does not support ANSI escape sequences.
[Attachment 77854 - Click to enlarge]
mpd.xml (1.mpd from log)
>N_m3u8DL-RE.exe --key 75395a425350585748325a646e73673d:6170704e6b7864645 f4544327a62493d https://kinescope.io/a9f71c89-b664-4045-ace2-c230171d7a13/master.mpd?expires=171103413...c8f154c1794044
21:07:39.100 INFO : Loading URL: https://kinescope.io/a9f71c89-b664-4045-ace2-c230171d7a13/master.mpd?expires=1711034139
21:07:39.262 ERROR : One or more errors occurred. (The SSL connection could not be established, see inner exception.)
"kinescope_project_id" не является внутренней или внешней командой, исполняемой программой или пакетным файлом.
"sign" не является внутренней или внешней командой, исполняемой программой или пакетным файлом.
[Attachment 77856 - Click to enlarge] -
No success still.
Also I tried download by yt-dlp:>N_m3u8DL-RE.exe --key 75395a425350585748325a646e73673d:6170704e6b7864645 f4544327a62493d "https://kinescope.io/a9f71c89-b664-4045-ace2-c230171d7a13/master.mpd?expires=1711034139&kinescope_project_id =c92691a6-57bc-47e6-b231-b2d9bb28b159&sign=8ca395a915d9a6d41cc8f154c1794044 "
09:09:43.970 INFO : Loading URL: https://kinescope.io/a9f71c89-b664-4045-ace2-c
09:09:44.276 ERROR : One or more errors occurred. (The SSL connection could not
Is any chance to download DRM protected video from kinescope?>yt-dlp.exe --merge-output-format mp4 https://kinescope.io/a9f71c89-b664-4
045-ace2-c230171d7a13/master.mpd?expires=1711034139&kinescope_project_id =c92691a6-57bc-47e6-b231-b2d9bb28b159&sign=8ca395a915d9a6d41cc8f154c1794044 --referer https://kinescope.io
[generic] Extracting URL: https://kinescope.io/a9f71c89-b664-4045-ace2-c230171d7
[generic] master: Downloading webpage
WARNING: [generic] Falling back on generic information extractor
[generic] master: Extracting information
ERROR: [generic] master: This video is DRM protected
You have to use the --allow-u to download it, but of course it will be unwatchable until you decrypt it.
This url: https://kinescope.io/a9f71c89-b664-4045-ace2-c230171d7 doesn't have any video for me, not sure if it's region locked or requires login. -
Hello
Please help me download from nday.club , they changed servers and method from post #38 doesnt work.
Link for example is https://nday.club/video/korol-artur-slavyanskiy-knyaz-britanii
I have tried as:
N_m3u8DL-RE.exe -H "Referer: https://nday.club/" "https://46401c0a-3c5a-44eb-ae1b-9ac6db282186.selcdn.net/316f5420eafbc88abddc5277f65b2c86/69f739fd-9012-4a80-bc74-d3aca7af8ce4.json/manifest.mpd" --key b9221d5ad918f6e52eb3ada7d6d66439:b486410040bb4c589 f066c276db9e2b8 -M format=mp4
The video is downloaded, decrypted, and pecked, but only 3 sec plays, then there is no sound and color bars on video.
[Attachment 77916 - Click to enlarge] -
Hello!
I can’t find the keys on the video https://kinescope.io/200586210 and I use a clear key file as per the instructions, last year I downloaded the video according to your instructions for example - N_m3u8DL-RE.exe "https://kinescope.io/video_number/master .mpd" --key 4471575a47353361466573754734493d:724a6451454665313 4366d4478756f3d -M format=mkv
everything worked well
Now there is no file and I can’t find the keys(((
please, help -
Help Downloading video
By gilbertati in forum Video Streaming DownloadingReplies: 4Last Post: 27th Mar 2021, 16:39 -
help downloading this video
By Lionking in forum Video Streaming DownloadingReplies: 7Last Post: 1st Dec 2020, 23:04 -
Help downloading a video
By mainblue01 in forum Video Streaming DownloadingReplies: 2Last Post: 1st Aug 2019, 17:15 -
downloading subtitles that are not part of video and are overlayed on video
By 3dsmaxed in forum Newbie / General discussionsReplies: 1Last Post: 7th May 2019, 03:41 -
Help me out downloading this video
By smithmike in forum Video Streaming DownloadingReplies: 3Last Post: 5th Oct 2017, 20:14
