Page 2 of 10
Results 31 to 60 of 276
  1. Originally Posted by LZAA View Post
    Need access.
    login: senabis647@fanneat.com
    password: zNe34lYk
    Free videos page - nday.club/video/open
  2. Originally Posted by lexaring View Post
    password: zNe34lYk
    You can paste the response of the mpd in Notepad, save it as bla.mpd, upload to transfer.sh and use n_m3u8-re to download.
    To get the kid:key just check the response of that clearkey?token in the network tab.
    Use base64 to hex to get the kid:key.
    click click2
    If I/my posts ever helped you, and you want to give back, send me a private message!
  3. Originally Posted by [ss]vegeta View Post
    password: zNe34lYk
    Didn't understand every 3d word, sorry. Ok, got it. It's too difficult to download. Too many workarounds.
  4. Originally Posted by lexaring View Post
    You don't have to apologize. Spend a few days reading this sub-forum and you'll get the hang of it.
    Nope, it's not that difficult.
    Just a sec, I'll record you a video and edit this post.
    [edit] it's in the next post of mine.
    click click2
  5. Again, only for interest: Does anybody know why yt-dlp downloads an encrypted video without allow-u? Normally it had to refuse download, hadn't it?
  6. Originally Posted by Quint View Post
    I think jack_666 said why in the latest of his posts between me and him. Search. Could be the same thing.
    Anyways
    @lexaring
    Here's a video tutorial
    https://drive.google.com/file/d/1SR_4v5893PFx2LlYN7GvBGoIXqg_1sPE/view?usp=sharing
    Here are the tools
    https://drive.google.com/file/d/1Zi_WfZuPNsSjyZ3skLTvMIxBmvyowwxp/view?usp=sharing
    Here are the links
    https://base64.guru/converter/decode/hex
    https://transfer.sh/
    You've been served.
    click click2
  7. N_m3u8DL-RE work also with mpd from local path, no need to upload
    and it support also Base64 value
    --custom-hls-key <FILE|HEX|BASE64>
    Specify the HLS decryption KEY. It can be a file, HEX or Base64
    so:
    N_m3u8DL-RE "C:\file.mpd" --custom-hls-key <BASE64_value>
  8. Thanks lomero, the fewer steps the better.
    click click2
  9. Originally Posted by lomero View Post
    so:
    Nice to know!
  10. Originally Posted by [ss]vegeta View Post
    Anyways
    @lexaring
    Here are the tools
    Here are the links
    You've been served.
    Woooohoooo! Absolutely fantastic! That's the way I needed it to be explained.
    I had some problems with the mpd step though, because of this (https://stackoverflow.com/questions/51687462/firefox-developer-tools-truncates-long-ne...-does-not-show), quickly fixed it but got the mux error right before merging - VCRUNTIME140_1.dll is missing error. After installing Microsoft Visual C++ Redistributable and starting over I finally got the desired result.
    This is mindblowing!
    Thank you all for your time and effort!
    @[ss]vegeta, @LZAA, @Quint
    Thank you VERY MUCH!
  11. Originally Posted by [ss]vegeta View Post
    How can I use it in your example? Where should I put it exactly (what to replace) in the example line?
    N_m3u8DL-RE.exe "https://transfer.sh/xxxxx/xxxxx.mpd" --key xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx -M format=mkv
  12. Originally Posted by lexaring View Post
    Well I guess you'll remove the --key xxx line and just replace with --custom-hls-key BASE64_blabla
    click click2
  13. Originally Posted by [ss]vegeta View Post
    use --custom-hls-key xxx
    and replace xxx with base_64 value found trough great vegeta video on post#38
  14. Originally Posted by lomero View Post
    Ok. But there are two values in the video (k and kid). Which one should I put there? I guess both, right?
    Like this --custom-hls-key xxxxxKIDxxxxxxxxxxKxxxxx?
  15. Code:
    N_m3u8DL-RE.exe --key 5a43424f6845694b554a49785661773d:6459645a5a67646375326748356a513d yourfile.mpd -M format=mp4
  16. Originally Posted by cedric8528 View Post
    Sorry, makes no sense. Where is the "--custom-hls-key" which should save some time by converting the Base64 code locally?
    Or did I miss something?
  17. I give you this command because the other one from Lomero doesn't work for me....
    maybe i miss something
  18. yep cedric. my post#39 it's just an hint
    not tested on this specific site
    maybe for this site need to convert base_64 value and use --key value
  19. Well we missed the obvious, and it's in the name... --custom-HLS-key. This site doesn't use HLS (m3u8). It uses MPEG-DASH (mpd).
    click click2
  20. Originally Posted by [ss]vegeta View Post
    Yes, now it makes sense!. Thank you!
  21. This site doesn't use HLS (m3u8). It uses MPEG-DASH (mpd).
    https://kinescope.io/309ca5f2-e7c7-4854-93eb-9df4a72e241c/master.m3u8
  22. Originally Posted by karapuz View Post
    By default, for me, it serves mpd. I see no m3u8.
    click click2
  23. Originally Posted by [ss]vegeta View Post
    Anyways
    @lexaring
    Here are the tools
    Here are the links
    You've been served.
    @[ss]vegeta
    You are a genius!!! The method really works with downloading videos from kinescope.io !!!
    Thank you so much from Russia!
  24. Originally Posted by Alex_Green View Post
    @[ss]vegeta
    You are a genius!!!
    I ain't no genius. I just spent a lot of covid-19 time on this and I had huge help and hints from awesome people on this forum.
    There are some geniuses here and often hidden (in plain sight).
    You are welcome.
    click click2
  25. Hi!
    I do everything according to the instructions.
    After downloading the audio file, I get the following error.
    What could be the problem?
    [Attachment 68457 - Click to enlarge]
    The list of files after completion looks like this:
    [Attachment 68458 - Click to enlarge]
  26. Files '.mp4' and '.m4a' are played?
  27. Originally Posted by LZAA View Post
    No.
    But this is my mistake.
    There are too many videos on my page - I'm confused about the "clear" responses.
    The instruction works, many thanks to the author!
  28. Member
    Jan 2023
    Kaliningrad
    Hello. Can someone tell me how to download this video
    example: https://kinescope.io/embed/d2538919-1050-4a2b-851d-285e532472e7
