    May 2022
    Greater NYC
    Hi!
    I use Power Point Slides that are saved as .JPG files and, then, imported to Camtasia to create videos for YouTube.
    Right now, the Slides are 10 inches by 5-5/8 inches and are saved at 96 PPI.
    What Size (in inches) and what Resolution (in PPI) should I be using?
    Thanks!
    Doctor T
  2. From where you're starting, the simplest thing to do is double the ppi to 192. That will export a 1920x1080 (pixel) image which is a standard YouTube HD widescreen.
    (Likewise you could double your slide size to 20 x 11.24 x 96ppi)
    In video, ppi is meaningless, that's for print. Pixel count is what matters.
    There is no absolute right answer. For example, I usually export powerpoint slides oversized so I can do moves within them in Camtasia (or other editing software.)
    May 2022
    Greater NYC
    Thank you, SMRPIX!
  4. Member Cornucopia's Avatar
    Always save your PPT slides as PNG, not JPG. You won't regret it.
