Hello.
I want to convert video from camera from AVC/MOV to h265/mp4 or mkv to store it in my hard drive, unfortunately, videos framerate is unstable and sometimes tend to drop, unlike audio, while encoder recognizes that it use CFR. In the end i got video with cfr, but audio isn't aligned to it which is a problem. What should i do with it?
I use Hybrid for whole process.
Don't know if one of these editing suites help, Just google them
MOVAIVI PLUS EDITING SUIT
WONDERSHARE FILAMORALast edited by realspeed; 8th May 2022 at 05:25. Reason: adding title
or
b. enabling "Config->Input->Decoding->CFR output"
might help depending on what you do with the video and audio in Hybrid.
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini -
Then, with the given information, I have not clue. Normally processing vfr content is no problem, assuming the content isn't damaged.
Advice to reencode audio (25fps to 23.976fps)
By BKloud in forum AudioReplies: 1Last Post: 25th Jan 2022, 09:20 -
How to properly process this video with Avisynth?
By elektro in forum Newbie / General discussionsReplies: 9Last Post: 7th Jan 2022, 10:53 -
Crossfade after telecine? Misaligned dupes.
By embis2003 in forum RestorationReplies: 2Last Post: 8th Nov 2020, 00:21 -
How does the audio sync properly for telecined video?
By 90sTV in forum Newbie / General discussionsReplies: 5Last Post: 3rd Oct 2019, 19:32 -
8mm transfer vertically misaligned
By tom_nito in forum EditingReplies: 6Last Post: 24th Nov 2017, 13:27
