Results 1 to 16 of 16
    Feb 2022
    Search the forum first!
    Could the automated parser that looks for (that was a : followed by a capital D )and the like be tweaked to spot it is appropriate only if there is leading whitespace?
    Trying to post <TL : DR> without spaces foists an unwanted smiley on the poor reader.
  2. Member DB83's Avatar
    Jul 2007
    Ok. But do explain what <TL : DR> is meant to mean. Forums rarely interpret html tags unless they are specifically provided for.
  3. you can write such word inside code bbcode. bbcode disable all kind of smiley.
  4. Isn't the tl;dr one being called used elsewhere on the internet
    Mar 2011
    Nova Scotia, Canada
    TL, DR is a common expression on web forums, it means "too long, didn't read". Just dont't use the colon. Easy.
  6. Member DB83's Avatar
    Jul 2007
    <tu : Fte> :d
    Feb 2022
    I've always taken tl:dr to mean too long didn't read. And that sums up much web usage, if one takes a cynical standpoint.
    But please do not take one example of pseudo-markup language and claim an exception; this happens with colons all over this site. I usually need to remove at least one in any long comments I may make.
    Feb 2022
    <tu : Fte> :d
    <tu:Fte>
  9. DECEASED
    Jun 2009
    Heaven
    SEMI-O.T.: While all computers in the world aren't allowed to get rid of the limitations from the 7-bit Era,
    we already can replace most emoticons or smileys with an emoji.
    P.S.: Probably this thread should be moved to the "Feedback" section...
    P.P.S.: This forumware still has a problem with emojis when one edits a post. :—/
    "Programmers are human-shaped machines that transform alcohol into bugs."
    Feb 2022
    Put it where you like - nothing alters the message. But if I were paying a monthly subscription to vBulletin, I'd be asking the question as to when it might get fixed.
  11. I'm a MEGA Super Moderator Baldrick's Avatar
    Moving to feedback.
    This is a very very very very very very very old vbulletin version. I don't think I will update it. But I can try fix it myself. In 0-10 years.
  12. I'm a MEGA Super Moderator Baldrick's Avatar
    They must put the text in code tags.
    Feb 2022
    Then shouldn't you tell 'them'?
    https://forum.videohelp.com/threads/406195-Exracting-PSSH-from-a-MPD-doesn-t-inc-KID#post2661240
  14. I'm a MEGA Super Moderator Baldrick's Avatar
    And disable smilies.
  15. Originally Posted by s-mp View Post
    I had a stroke reading this. What i meant is that most people use semicolon " ; " when doin' tl;dr
