hii any one explain about lossless images and how to create them
i am thinking to make little animation from images which i make
i need guide before starting..
Results 1 to 28 of 28
AnonymousGuest
Not sure what you want to do, but may be OpenToonz (https://opentoonz.github.io/e/) does what you want,...
users currently on my ignore list: deadrats, Stears555, marcorocchini -
Common lossless image formats would be a format like bitmap (.bmp) , or png
What kind of drawing ?
for lightweight - ms paint
more features - krita (paint), gimp (more for photo manipulation, but has many plugins), inkscape (vectors) -
AnonymousGuest
For low res, pixel art, limited color pallette try grafx2
http://grafx2.chez.com/
There are tutorials on YT -
AnonymousGuest
All created images will be lossless??
Even if i use ms paint ,will it compressed while saving?? -
AnonymousGuest
bmp is uncompressed (no compression)
png uses lossless compression. If you decompress png to bmp, you get the same thing as if you saved as bmp in the first place.
There are slightly different types of png compression , but all of them are lossless. png are slower to compress and decompress than bmp assuming you do not have transfer bottlenecks (eg. slow hard drive) -
AnonymousGuest
Thanks I'll try some drawing ,btw any one know good and simple game engine for windows..which uses simple programing language
IMO, Good and simple are mutually exclusive with game engines. I would recommend using a known powerful standard, such as Unreal.
Scott -
BMP can be compressed or not - usually RLE compression is used.
https://en.wikipedia.org/wiki/BMP_file_format#Compression -
Pandy is right in that bmp can be either (losslessly) compressed or uncompressed, but I disagree - my experience is that the VAST majority of bmp files out there are totally uncompressed RGB, as can be verified by their filesize, as well as peeking into their contents.
Scott -
Because we don't live in the last century anymore. Who creates games for Amiga, anyone?
AnonymousGuest
I wanna create a simple game in game engine which will display animation from image sequence at some fps and also play a soundtrack in background
for image sequence i am finding a software which will generate lossless png sequence of txt animation or any animation,Last edited by Anonymous543; 11th May 2022 at 00:52.
Some of them are available as preorder, some of them are WIP - bellow only few examples - there is more.
https://www.youtube.com/watch?v=CliGgY8v1fM
https://www.youtube.com/watch?v=UE4nOYc0RkA
https://www.youtube.com/watch?v=gB9-7OxBSEs
https://www.youtube.com/watch?v=Ugx0uhPYzdk -
AnonymousGuest
i found one game engine which is very lightweight and easy to start with it
game engine's name is love2d -
anything would work. Unless you are talking about smartphone apps, every single program should have either png or bmp as an option
Does anyone here know how to use these lossless codecs?
By Guernsey in forum Newbie / General discussionsReplies: 16Last Post: 25th Jul 2021, 17:17 -
Lossless Ripping of TV Episodes from DVD ISO Images
By gibbdude in forum Video ConversionReplies: 6Last Post: 8th Jun 2021, 12:56 -
a bunch of images that i want to add to openshot - can i make a film now
By gibraltar in forum Newbie / General discussionsReplies: 3Last Post: 29th Nov 2020, 14:40 -
Quick sanity check: Lossless to lossless encoding HuffYUV to UTVideo
By nicholasserra in forum Video ConversionReplies: 2Last Post: 20th Aug 2020, 11:41 -
FFMPEG - hevc_nvenc & h264_nvenc lossless presets not truly lossless?
By AnomalyDetected in forum Video ConversionReplies: 5Last Post: 27th Oct 2019, 02:24
