Sorry to bother you all, but I used to use bookmarklet to catch m3u8 of IQIYI and VIU. And I also tried to find a bookmarklet for LineTV, but I can't find one. What's worse, I don't know too much about js...So I wonder could anyone be so kind to have a look at it and I'd appreciate it a lot if anyone could also make a bookmarklet for LineTV which is really friendly to non-technical people like me to use. (Please forgive me that my English is not so good..
https://www.linetv.tw/drama/13213/eps/1?drama_id=13213&source=SEARCH_RESULT_PAGE
LineTV need Taiwan VPN
I'm not technical but here can be the reference from the github user nilaoda, if anyone need:
https://gitcode.net/mirrors/nilaoda/N_m3u8DL-CLI/-/blob/12eb68d59218e978b019698b6152f9..._codechina=yes
And the iqiyi m3u8 bookmarklet I'm using is also from him.
Results 1 to 9 of 9
Here you go
Converted to BookmarkletCode:(function () { let masterM3u8Url = player.tech_.currentSource_.src; prompt("MASTER M3U8 URL", masterM3u8Url) })();
(Just add it manually on your bookmark as page)
Code:javascript:(function()%7B(function%20()%20%7Blet%20masterM3u8Url%20%3D%20player.tech_.currentSource_.src%3Bprompt(%22MASTER%20M3U8%20URL%22%2C%20masterM3u8Url)%7D)()%7D)()
Hi! Thanks a lot for your kindly help! But when I use the app that I usually used to convert m3u8 into videos, it showed "failed to fetch the key". I attached the zip of the app with my message. I don't know why it showed like that. I'm sorry for bothering you again.
N_m3u8DL-解决IDM无法下载受保护数.zip -
That's all I can help for now (unless if I'm not busy) since you're request only is to grab m3u8
Just wait for other to help you further.
All I know is that it can't find the m3u8 key URI which use to decrypt the encrypted .ts files
You can try to explore it. Just paste this on chrome console after you play the video
player.tech_
It will give you more informations maybe you can find there the KEY URI.
If you've successfully found the URL, right click on the header of that location and click "Copy property path" then do like
e.g. (separated by dot)
player.tech_.THIS_IS.THE_KEY_PATHLast edited by zackmark29; 1st May 2022 at 19:30.
streamlink --http-header Cookie="_t_cid=6f11b764-f159-4dee-af64-245ab73deebe; _t_sid=392b07ee-eddd-4198-b4a5-0c2d74373642; view.id=13213_1; connect.sid=s%3AGlCfiLTtxRcEsvyWIXcJzArf9zakh4wz.R VFmXr51HOpvFAxEeHDGL498uBvyqNK9WYtT64MnpRE" "https://d3c7rimkq79yfu.cloudfront.net/13213/1/v1/13213-eps-1_SD.m3u8?Expires=1651524018962&Key-Pair-Id=K3A3HFLQY0L90Y&Signature=wUtPpS3t9E5gfuW6CNV6ih lbNv07f5HyqkCyCfQwA5fPCWpWE374kZfuhc1fQDisAphUst~Q-Ynj5KwWrUNVjqPR2dH0WjjA0kp4gF5LOfc5Y7qrX1SaeOq5oXh SesXaT1SOYbFg-1OFjx2wRnhyzulyy~BLExhsHNmtTXplmTdm3djWnoIQJFn8BwC D8KuFLfVNVt-2kMoQROxSHuiEJsakIXHK~~LFxXeMTuZL3qXD3yD1H7kqFjqaq uu8GyBxSjvHbHAPs0YiqtM4GzE7iBP2pNFTK2pOmgBiZi3BNda pKN6Xu3QrsK4zzgAMfBRcr7nDHDwiMal0Bxb7SBKJsQ__" best -o video.ts
[cli][info] Found matching plugin hls for URL https://d3c7rimkq79yfu.cloudfront.net/13213/1/v1/13213-eps-1_SD.m3u8?Expires=165152401...l0Bxb7SBKJsQ__
[cli][info] Available streams: 360p (worst), 480p (best)
[cli][info] Opening stream: 480p (hls)
[download][video.ts] Written 4.5 MB (50s @ 90.0 KB/s) ...Last edited by LZAA; 3rd May 2022 at 15:15.
how to get m3u8 from this video
By ningnong132 in forum Video Streaming DownloadingReplies: 8Last Post: 20th Jul 2021, 09:01 -
Color discrepancy on "catch-up" TV videos from the same programs
By abolibibelot in forum Newbie / General discussionsReplies: 15Last Post: 6th Aug 2020, 16:11 -
How to make a .m3u8 file ?
By DWIChannel in forum Newbie / General discussionsReplies: 4Last Post: 18th Jul 2020, 06:21 -
m3u8 > rtmp ?
By skc109s in forum Video Streaming DownloadingReplies: 6Last Post: 11th Jun 2019, 20:38 -
Help--Need help to catch a fugitive from a cctv footage
By Aruna in forum Newbie / General discussionsReplies: 14Last Post: 18th Dec 2017, 10:55
