Hello,
I'm trying to fix the edges/borders of a frame as usual.
I have already encountered these kind of artifacts, and didn't care too much 'bout them,
I'm talking about the different bright in the columns 1 and 1478(of the scripted frame), which is it is not continuous, but intermittent.
The effect is that you see some kind of "holes".
but now I'd like to know if there's a command to fix a specified column in order to vanish/shade/fade away those artifacts.
I mean something like bbmod but that works vertically on a single column.
does it exist?
this is the source frame: https://www.dropbox.com/s/x7j3ozjhxsgyjn4/1%20source.png?dl=0
this is the script I'm using
this is the result: https://www.dropbox.com/s/qnuan9jml9inl4o/2%20rip.png?dl=0Code:crop(220, 0, -220, 0) FixCBr(0,32).FixCBr(1479,32) bbmod(0,0,2,2,128,8)
as you see artifacts are not fully corrected, no matter how high is the bbmod value. (which anyway I'd like to keep under 2)
that kind of dotted line, darker and lighter, like a morse code, the columns 1 and 1478.
https://www.dropbox.com/s/bejzuipyu4lj28v/sdr%20ss2.png?dl=0
Chroma sample location - what should I do?
By bokeron2020 in forum Video ConversionReplies: 5Last Post: 24th Aug 2021, 18:02 -
How to denoise this sample?
By capfirepants in forum RestorationReplies: 16Last Post: 27th Nov 2020, 11:41 -
AI upscaling using a sample as reference?
By CGI979 in forum RestorationReplies: 2Last Post: 10th Aug 2020, 23:59 -
TS sample with Dolby-E
By Arun08 in forum Video ConversionReplies: 4Last Post: 9th Jun 2019, 04:10 -
Suggestions for this sample
By gamjerr in forum Video ConversionReplies: 1Last Post: 20th May 2017, 23:06
