Hi, it's me again with another 29.97fps sample.
I've tried the command TFM().TDecimate(), it removes duplicate frames but not the correct ones,
some interlace artifacts are visible, like in this ss (the guy's arm on the left):
https://www.dropbox.com/s/d7ktf8343bvc3dj/tr%20sample%20ss1.png?dl=0
sample: https://www.dropbox.com/s/a473wgffl02d1tc/tr%20sample.mkv?dl=0
can I please have some help?
Those artifacts are in the source fields, probably from the encoder inaccuracy. It's not a field matching or decimation issue. (If it's just a few frames, it's pretty easy to fix by masking it out in a compositing program; because those frames have a static camera and you have clean areas on adjacent frames to provide coverage)
Decimation works ok for me , correct duplicates are discarded. Maybe problem your source filter ? Or maybe TIVTC version ? -
There's no interlacing in the sample video -- it's already been deinterlaced. Those artifacts were caused by that poor deinterlacing. So there's no need for TFM. Use just TDecimate().
Thanks you both poison and jagabo, for the information. really appreciated.
First of all, yes the command TDecimate() works, I thought it wasn't cause of those artifacts "included" in the source. as you said.
I have to upload another sample, this: https://www.dropbox.com/s/y1s0nmppcz4noyx/jc%20sample%202%20with%20interview%20parts.mkv?dl=0
it includes interview parts, so I have interview plus movie parts alternatively.
If I have to choose one, I prefer to fix the interview parts and let the movie parts at their destiny.
But I'm not able to understand:
0 - the original filename is "m2ts_ - 1 - h264, 480i60.mkv.avs", even if I can't really see any interlaced frame in the source,
I presume it is interlaced and it must be fixed, doesn't it?
1 - Have I to use TDecimate() fo the whole bonus? is it good for interview too?
2 - Have I to use another command in order to fix the interview parts only?
secondary question: is it this the correct use for z_Spline36Resize?
I mean could it be used when I crop horizontally too?
final script:
Code:#NTSC 16:9 720 x 480 40:33 ITU ON crop(98, 2, -98, -2) z_Spline36Resize(524,474,0,1,0,-1) bbmod(1,1,0,0,128,8) TDecimate() Prefetch(7)
You can't judge by the name -- anybody can name a file whatever they want. You can examine the video properties with MediaInfo. It says your two videos are interlaced. But that's how they are encoded -- not the actual content of the frames. The new video is encoded interlaced but the frames were deinterlaced before encoding. So the content of the frames is progressive. I think the interview sections were shot with an interlaced video camera and deinterlaced with a "discard field and duplicate the remaining field" algorithm -- leaving you with 30 unique frames per second. The film sections have 24 unique frames (aside from deinterlacing and encoding artifacts) out of every 30 frames.
TDecimate() is good for the film sections but will make the interviews jerky. Conversely, you could skip the decimation and have smooth interviews but jerky film sections. It's also possible (with some difficulty) to mix the two methods and encode with a variable frame rate, ie, 24p for the film sections 30p for the video sections.
You can smooth the edges of the video sections with QTGMC(InputType=2). That will probably help with some of the similar artifacts in the film sections.
Smoothness will be similar to the source but there will be fewer aliasing artifacts.Code:LWLibavVideoSource("jc sample 2 with interview parts.mkv", cache=false, prefer_hw=2) QTGMC(InputType=2)
tdecimate dupe frames in certain pattern
By midts in forum Video ConversionReplies: 30Last Post: 20th Dec 2021, 16:20 -
When to TDecimate/SRestore?
By Okiba in forum RestorationReplies: 118Last Post: 18th Aug 2021, 04:55 -
TDecimate scrip problem
By kalemvar1 in forum Video ConversionReplies: 4Last Post: 14th May 2020, 14:35 -
Quick question on TIVTC's Tdecimate
By attackworld in forum Newbie / General discussionsReplies: 4Last Post: 11th Mar 2019, 16:05 -
TDecimate vs. Srestore?
By Vitality in forum DVD RippingReplies: 11Last Post: 19th Jan 2019, 20:13
