I want to cut a VCD MPEG1 .Dat file frame accurate losslessly if possible. How to do that? It's a 22 year old .dat file in MPEG1 audio and video vcd file
VirtualDUb should be able to do that... you might have to rename it into .mpg.
MPEG1 is an interframe codec so it cannot be cut frame accurately and losslessly. At least the cut GOPs need to be re-encoded.
To add to what jagabo said, while MPEG1 has the general capability of being I-frame-only, when used in VCD context, it is ALWAYS multi-frame GOP.
And I suggest if you have a *.DAT on a VCD, that you do NOT just simply rename it, ESPECIALLY if you intend to edit it. Rip while removing the VCD's Mode2Form2 sector garbage FIRST. In doing so, you should be left with a straight MPEG.
Possible New frame accurate cut/merge Program
By Budman1 in forum EditingReplies: 4Last Post: 27th Mar 2026, 01:44 -
Getting an accurate frame count for whole video
By Fern99 in forum Newbie / General discussionsReplies: 9Last Post: 29th Jun 2021, 17:12 -
App cut frame by frame HEVC
By kiki_vg in forum EditingReplies: 14Last Post: 31st May 2021, 09:03 -
Frame accurate H264 Editor
By 557953 in forum EditingReplies: 5Last Post: 24th May 2018, 15:15 -
Frame-accurate trimmer with subtitle support
By Schmengland in forum EditingReplies: 20Last Post: 9th May 2018, 16:43
