Hello, I got a Single VOB file (No DVD) with aac-Audio.
Now I got the same Audio as lossless PCM (FLAC) Audio.
Is there now a simple way to replace the aac-Audio from the VOB with the lossless Audio?
Output should still be VOB.
Thanks for any help!
Results 1 to 11 of 11
You must convert your pcm in pcm 16bit big endian (pcm_s16be).
Use clever FFmpeg-GUI to convert and to mux. -
Before proceeding: if you intend to put the result back on DVD, be mindful of your combined bitrate so that you do not go over the spec legal limit. That is VERY OFTEN the reason that AC3 is used in the first place, as the majority of the bitbudget is usually devoted to the video.
Scott -
Yes, and what makes that more obvious is that dvd-video spec was developed 5 years before flac, and the spec had no real revisions after it was finalized, so there's no way the dvd folks could have known, prepared for, or even imagined the common usage of flac in modern scenarios.
Scott -
VOB (unsplitted or smaller than 1 GB) and MPG are the same, except that VOB has nav-packs for DVD authoring which are not needed when played back as a stand-alone file.
VOB tends to have a better reputation in some parts of the web as it usually implies DVD quality, whereas "MPG" can be anything between VCD to SVCD to DVD. But technically, VOB should only be used in a DVD structure, not as a stand-alone file.
replace menu intro vob on a dvd
By brianvlez in forum Authoring (DVD)Replies: 8Last Post: 2nd May 2020, 14:35 -
Replace subtitle in a sub/srt file
By Adhyskonydh Bobobobo in forum SubtitleReplies: 2Last Post: 15th Apr 2020, 03:45 -
Audio Delay from conversion of VOB file
By changie in forum Newbie / General discussionsReplies: 6Last Post: 18th Dec 2019, 05:37 -
How to replace video & audio streams with other in .ts file?
By VetalSai in forum Video ConversionReplies: 0Last Post: 14th Jul 2019, 10:15
