  1. Hello,
    I got a single VOB file (no DVD) and Subtitles for the content in .srt Format.
    Is there a way to add/mux them into the VOB file as you can with other Formats (MKV, ...)?
    Output should still be VOB.
    Thanks for any help!
    p.s.: I do not want to hardcode them into the Video, I just wan them to be selectable when playing the Video.
  2. You could remux the vob to mkv, adding the srt sub.
    Can be done with clever FFmpeg-GUI.
    If you want to keep vob as output, you first need to convert the srt subtitle to vobsub (idx/sub) with Subtitle Edit and then add the idx stream with clever FFmpeg-GUI in multiplex panel.
  3. Originally Posted by ProWo View Post
    Can I then rebring it to VOB?
  4. SRT is no good for VOB (DVD). It has to be converted to a compatible format - SST or SUP for Muxman (free Authoring program). So, demux your VOB into audio and Video. DGIndex is one way. Then follow Baldrick's Method 2 in this guide:
    https://forum.videohelp.com/threads/277950-How-to-add-new-subtitles-to-an-existing-DVD
    You'll wind up with a DVD in which you can choose to play your subtitle. There's no way to have selectable subtitles muxed into a VOB file. You'll need the DVD.
  5. Originally Posted by ProWo View Post
    It says it can't mux pcm audio into vob container...
  6. Originally Posted by Freaky2003 View Post
    pcm audio or vobsub subtitles? No confusion, please.
  7. DECEASED
    Jun 2009
    Heaven
    The (m2)ts container supports image-based subtitles.
    TSMuxer can convert .SRT files to Blu-Ray subpics.
    "Programmers are human-shaped machines that transform alcohol into bugs."
