    Mar 2017
    North Carolina
    It's been a while since I last used FF so I'm having to relearn operating instructions. On the page showing the finished converted files, I see an arrow, either red or green. I've sampled both and either type file seems to work fine. Just what is FF trying to tell me with these red/up or green/down icons?
    Aug 2006
    FF = FormatFactory or something else?
    Mar 2017
    North Carolina
    yes, FF = Format Factory
    Aug 2006
    I have never used Format Factory so I can't help you but now that the name of the program you are using has been confirmed, maybe the chances of someone else helping you have improved slightly.
    Mar 2017
    North Carolina
    Thanks for your response, usually_quiet.
