Results 1 to 1 of 1
  1. hi there,
    I've extracted a BD bonus content, a director interview, like I often do: by using useac3to.
    it extract the video, an MPEG2, 480i60, subs in 6 different languages and 5 PCM audio files.
    The weird thing is these PCM files have all the same name, english tag and size.
    while I try to open one of them in mpc-hc, it says it cannot render the file.
    if I try to use audacity, it can import the PCM but the sound is extremely amplified and nothing can be understood.
    If I try to open it in useac3to in order to convert it to FLAC or AC3, I just cannot and the useac3to message is:
    "This might be a RAW/PCM file. Trying to figure out the details.
    This will probably take a while. Please be patient...
    Was not able to figure out all parameters of this RAW/PCM file.
    Please specify channel, bitdepth and endian parameters via command line."
    what's going on?
    edit: ok nevermind, sorry, I just realized that if I convert them to flac directly, instead of extract them in PCM, it works.
    edit2:
    the problem is another now:
    apart the incorrect audio tracks names which are always the same...
    the bonuses are four, but
    the n°2 video is cutted around 15m,
    the n°3 is cutted around 12m,
    the n°4 is complete but its lenght isn't 20m but 15m.
    the n°5 is complete but its lenght isn't 20m but 12m.
    2) 00002.mpls, 00003.m2ts, 0:24:49
    - MPEG2, 480i60 /1.001 (16:9)
    - RAW/PCM, English, stereo, 48kHz
    3) 00003.mpls, 00004.m2ts, 0:20:15
    4) 00004.mpls, 00005.m2ts, 0:19:53
    5) 00005.mpls, 00006.m2ts, 0:19:51
    what's going on? help please
