im having a hard time twith this i have win xp and a pioneer dvr-104 and get errors each time i try too erase a dvd-rw :/ havent tried a cd-rw but is there a fix for this?
You might want to post the error message and what software you're using to do the erasing.
I hope you are using approved media. Some DVD-RW media do not work in the 104. Use only Pioneer, TDK, Verbatim or Mitsui. Most of the other brands you will get errors.
RG -
I use Princo generic DVD-RW (which I'm sure isn't an approved media) to test all my DVD compilations. If they turn out bad, then I simply erase them (I use NERO 5.5.8.0). Sometimes they take a little "extra time" to erase, but they have never failed to erase. -
SLK001,
Did you read the question? Sounds like you have the answer just continue to try to erase and you will eventually succeed. Of course when you get around to writing you might write a disk and not all your data will be there when you finish. I hope you are doing a data verification with Nero. The best bet is to use good media not that Princo crap.
RG -
SLK001,
I was wary of these Princos, especially since my experiences with their DVD-Rs (all crap). But I am not any more. At $2.00 each, they are my best value in DVD-RW.
Pioneer DVR-520h or DVR-220 or DVR-225 replacement DVD-RW drive
By psymaster in forum Newbie / General discussionsReplies: 1Last Post: 31st Oct 2009, 19:48 -
By psymaster in forum Latest Video NewsReplies: 1Last Post: 31st Oct 2009, 17:26 -
Problem erasing a Verbatim DVD+RW
By nadizo in forum DVD RippingReplies: 10Last Post: 2nd Mar 2009, 07:56 -
Replace Pioneer DVR-104 with DVR-115D? EIDE cable the same? Other questions
By Goldenvoice in forum DVD & Blu-ray WritersReplies: 1Last Post: 13th May 2008, 07:20 -
Daytek DVR-P30: lots of 'fails' when erasing, lots of nothing when recordin
By buzzinhornets in forum DVD & Blu-ray RecordersReplies: 6Last Post: 20th Jul 2007, 15:43
