Results 1 to 22 of 22
  1. Hello dear community,
    I have a video, that has a semi-transparent watermark.
    I have installed AviSynth+.
    I'll played a little bit with InpaintDelogo, but with no luck.
    Can anyone please help me and post me a script, that can complety remove / deblend this watermark?
  2. Thanks for this link. I have also tryed this, but I have no luck, to remove to logo completely / correctly.
    I tryed to deblend. But a lot of gray is ben left on my try's. Can you post the correct parameters for my logo?
  3. The video i can't upload public of some reasons...
    I tryed these scripts (The "Loc" is another, because in screenshot it's only a part from the video, I cutted some of left part of the screenshot):
    1. With InpaintDelogo:
    Import("InpaintDelogo.avs")
    LSMASHVideoSource("C:\Users\admin\Desktop\video_wa termark_remove\input.mp4")
    InpaintDelogo(mask="C:\Users\admin\Desktop\video_w atermark_remove\mask_1.bmp", Loc="44,372,-36,-18", Analyze=-4, Mode="Deblend")
    2. With this way:
    logo = ImageSource("C:\Users\admin\Desktop\video_watermar k_remove\mask_new.png").ConvertToYV12()
    src = LSMASHVideoSource("C:\Users\admin\Desktop\video_wa termark_remove\input.mp4").ConvertToYV12()
    logo=logo.ColorYUV(gain_y=-19, off_y=-19) # adjust logo levels
    Overlay(src, logo, mode="subtract") # subtract logo from image, leaves bright areas too dark
    bmask=src.ColorYUV(gain_y=950, off_y=-440).GreyScale() # mask based on brightness
    Overlay(last, src, mask=bmask) # blend original with delogo'd video
  4. Can anyone please help me to completely remove the watermark? I can pay $$.
    Feb 2006
    try doing a search - https://www.videohelp.com/search?q=remove+watermark+from+video
  6. I alredy spend a lot of days and readed any thread here... nothing can remove the logo with good results...
  7. Video Damager VoodooFX's Avatar
    Oct 2021
    At Doom9
    You need to understand what is written there.
    Without the video you are on your own.
    Drop 10 pxs on Loc coords.
    Analyze=-4 is not good for a deblend mask creation.
    Analyze=1 would give best results, but probably it will be too hard for you to utilize it.
    Try Analyze=-3, a bit worse results, but easier.
  8. Thanks... I try to give my best...
  9. Granted, without knowing ins and outs it is next to impossible how to use this tool. Is there a good tutorial for greenhorns? Like:
    • what are the types of image removal
    • when a particular type should be used
    • how mask is generated, where it is stored, and how to [re]use the stored mask
    • how to define a mask manually
    • what's up with the coordinates (ok, it seems that right and bottom are offsets from the right edge, and hence they are negative, but how one would know this?)
    • what if the logo consists of two parts: solid and half-transparent - do I need two masks? Do I need two passes?
    • which parameters can be combined with which?
    These are just some of the questions. If there is no a clear and concise tutorial, I would not mind writing one myself, but to do this I need to understand how this works
  10. Originally Posted by VoodooFX View Post
    Everything is in the manual.
    By the manual do you mean the source code for your script?
    Aug 2004
    PA USA
    You shouldn't be removing other people's watermarks; did you shoot the video? do you own the copyright? No? don't do it.
    It's not important the problem be solved, only that the blame for the mistake is assigned correctly
  12. Originally Posted by ConsumerDV View Post
    No, he means the AVSI itself. Open one up and see.
    Well, I remove logos and watermarks all the time and I didn't create them. However, the videos are in the public domain and deface otherwise perfectly good movies. So, I think your suggestion needs some clarification and context.
  13. Video Damager VoodooFX's Avatar
    Oct 2021
    At Doom9
    There is something in Doom9's thread, but I wouldn't say that it's "good tutorial for greenhorns", best is to read the manual/help and try to connect the dots, it's at the top of avsi.
    Then ask what you don't understand in forums, understanding comes with practice, try to remove few logos.
    Be my guest and do it. I can't write a tutorial for "greenhorns" myself, because I don't know what "greenhorns" don't understand, memories of my green times 20 years ago are murky.
    Most of those questions are answered in the manual, so here are superficial answers:
    1) a) Deblending. b) Inpainting. c) Mix of both. d) Taking undamaged part from similar video.
    2) a) Transparent. b) Opaque, Hardly-transparent. c) Transparent-Opaque, Transparent-Hardly-transparent. d) All of mentioned.
    3) Read about "mask", and doom9 thread, practice.
    4) Base mask by "mask" parameter, deblending masks are picked automatically.
    5) Read about "Loc". Read about Avisynth's "Crop" [both coord systems are supported].
    6) Read about "oTune". No, but sometimes two passes can be useful.
    7) Read the manual, there are sections, mentioned sub-parameters ect..., and there is connections scheme [not maintained from v1.20], practice.
    That's probably hardest to get, there are ~80 parameters.
    EDIT:
    I remembered my first thought when I looked at Avisynth first time: "WTF is this?".
    Aug 2004
    PA USA
    We don't know where the opp obtained his movie, probably the piratebay or some such site. I seriously doubt what you're downloading is public domain just because it's online somewhere.
    This is all pointless anyway, he's not getting rid of that logo even if he pays.
  15. Looking at that sample. The color is there under that print. So you just need perfect mask and then add something to Y channel, smooth it out?
  16. Originally Posted by sum_guy View Post
    I seriously doubt you know what you're talking (writing) about.
    I can't speak for the OP, but you made a blanket statement that isn't true in all cases and certainly not in my cases, which include quite a few YouTube videos.
  17. Video Damager VoodooFX's Avatar
    Oct 2021
    At Doom9
    Sounds like CSI science.
  18. Can anyone tell me what's AVSI?
    click click2
    If I/my posts ever helped you, and you want to give back, send me a private message!
  19. users currently on my ignore list: deadrats, Stears555, marcorocchini
