lets say i have an interleced video. how do i tell yadif in ffmpeg to only output the bottom fields and leave the top fields ? i don want frame doubling.
ty
will select the bottom fields, discard the original top fields, but interpolate a new top field, giving you a full frame size. e.g. 720x480 for "NTSC" or 720x576 for "PAL"Code:
-vf yadif=mode=0:parity=bff
Or did you want just the "half height" original bottom fields ? 720x240 for "NTSC" or 720x288 for "PAL" ?
Yadif Vs QTGMC Comparasion
By AntonHarboe_ in forum RestorationReplies: 7Last Post: 5th Dec 2021, 17:18 -
yadif custom settings
By radusound in forum DVD RippingReplies: 18Last Post: 14th Dec 2020, 09:41 -
[avisynth] is there an alternative to YADIF?!?
By marcorocchini in forum Newbie / General discussionsReplies: 37Last Post: 15th Jan 2020, 18:19 -
Deinterlacing with VirtualDub's Yadif filter?
By dellsam34 in forum Capturing and VCRReplies: 44Last Post: 29th Jul 2019, 14:27 -
How to use Yadif to remove this one bad frame?
By digicube in forum RestorationReplies: 2Last Post: 18th Jun 2018, 21:47
