Is it possible to copy the material on it and transfer to another?
Results 1 to 9 of 9
As long as it can be discovered by the OS then it can be copied. Remove the HD and connect to your computer. You should hear it spinning. Check the OS to see if it was discovered. If it was, then use of several programs to copy to another drive.
As long as all the drives are ide,can't do it if there are any sata drives.
There are adapters that allow connecting an IDE drive to a modern computer's USB port. Here is one example that also supports SATA drives: https://www.amazon.com/Adapter-FIDECO-Converter-5-25-Inch-DVD-ROM/dp/B077N2KK27/
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
Why not just plug in a usb flash drive and copy the files there?You can move the files to any computer with no issues.
I looked at the manual. The USB port does allow connecting a USB HDD or USB flash drive. (The drives must be FAT32 formatted). Audio files and jpg photo files can be copied to or from attached USB storage devices to the internal HDD. Maybe I overlooked something, but I didn't find any mention of copying video recordings from the internal HDD to an attached USB drive.
the receiver uses copy protection on the recordings - https://www.manuals.ca/samsung/dtb-p770v/manual?p=75
page 75/131 -
Then you can't copy anything.
According to that page in the manual, the copy-protection is macrovision. But would it natively record as such or simply accept, as what happened in the past with our sat. broadcaster that they sent copy-protection signals for certain channels and the STB simply decoded that for playback.
Either way, and even if the signal is recorded, you should still be able to capture the playback in real time with a device - and they do exist - that ignores mv. Of course if the mv variant was proprietory then there is no guarantee that even this would work.
Only one way to find out.
Samsung DTB-P770V
By OldSchool297 in forum DVB / IPTVReplies: 2Last Post: 2nd Oct 2023, 00:01 -
Hard Drive Reliability
By cornemuse in forum ComputerReplies: 6Last Post: 22nd Aug 2021, 10:32 -
Samsung dtb-p770v change HD.
By OldSchool297 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 9th Nov 2020, 20:41 -
Samsung dtb-p770v power problem.
By OldSchool297 in forum DVD & Blu-ray RecordersReplies: 8Last Post: 3rd Sep 2020, 19:38 -
Backing up all my disks to a hard drive
By kshavo in forum DVD RippingReplies: 20Last Post: 26th May 2019, 03:55
