Why I would need your encoded file? Share originals only.
Results 151 to 172 of 172
Increased luma range fixed it:
Old vs New:InpaintDelogo(Loc="4,990,-1380,-4", DynMask=3, DynTune="140 - 215", DynColor=$FFB900, DynColorTol=65, DynInflate=2, Dyn3Seq=52)
No idea. Ask the developer -> https://github.com/gispos/AvsPmod/discussions
Command line resets too.
I've set it to CRF 19 now, but files are getting quite big. Bigger then the orriginal files together
You're right.
This appears to work: look in the tools folder. Edit encoder_gui.py with Notepad. Change the line:
to:Code:self.ctrlDict['ffmpeg'] = (_('Quality CRF (0-51):'), 21, 0, 51)
Note only the value 21 was changed to 19. Save the file.Code:self.ctrlDict['ffmpeg'] = (_('Quality CRF (0-51):'), 19, 0, 51)
I suspect you'll have to repeat the edit after upgrading. -
This seems to work yes, Thanks!
I've set the standard value back to CRF-18 now and the results looks great! Nailed the timestamp completely with the help of both of you!
https://www.youtube.com/watch?v=wYUqaVSQXpA
Well, because it does not to seem verry consistent.
All the clips are filmed with the same camera with the same settings. They're all about 400 to 500MB in size (for the full 3min. cut) and have all a bitrate around 20.000kps.
I'm using the same scripts and settings for all the video's now. And 1 video comes out 2 à 3 times the size of alll the clips combined with a bitrate of over 50.000kps. While other video's come out half the size with a bitrate of around 10.000kps.
And other video's come out almost in the exact size and bitrate.
All with the same settings. -
That is the entire point of crf encoding. The camera you are using appeasr to output a constant bitrate of 20 Mb/s. For some of your clips that was way more than was necessary (the nearly all black one for example). For others it was woefully too little (the motorboating video has lost most of the detail, is full of blurry blocks, and DCT ringing in the choppy water, the sky is badly posterized). Of course, the damage is already done. x264 is trying to prevent more damage.
Oh I see, thanks for clarifying this. Makes sense!
I was thinking already that there should be a big difference in information in a video that is mainly dark. Or a video which contains a lot more of detail.
I've decided to export all in CRF18.
Some files will come out much bigger this way. Others much smaller, like the night video's. It compensates a bit
I was thinking that going much lower then 18 shouldn't make much sense either. Because it's clearly no 4k quality that I'm trying to maintain here haha
Edit:
One file reached 10GB now haha
Update:
Sorry, got a lot of things on my head since my last visit. But I still would like to thank everybody who had helped me in this, especially @VoodooFX for providing this great way of removing the timestamp!
I managed to edit the video's now, these are some results now:
https://www.youtube.com/watch?v=Bn0CA0Qm4vg
https://www.youtube.com/watch?v=TVpPvFOmymE
And I'm happy to have removed the timestamps with you help. It prevented me of cropping a lot. At some detailed parts there's still a bit of a blurry background, but it actually doesn't botter me. I'm verry happy having removed the timestamp!
Question @VoodooFX:
To my understanding, did you had to adjust/ customize the timestamp mask to fit my specific video timestamps? -
The timestamp removal is pretty good but why is the video encoded at 50p? The sources appear to have been 30 fps and 60 fps. 60 fps would have given smoother results.
It was the only option Pinnacle studio was giving regarding to the NTSC/PAL settings. It let me only choose between 25/50 in NTSC and I believe 30/60 in PAL.
But yes, the timestamp removal looks really good! I'm glad being helped out with this!
Yes! It looks really good. Sometimes it's more visable then other times, depending on the speed and the details. But it's that I know that there was a verry annoying timestamp before. At other parts it completely not noticable annymore. I'm verry happy with it!
Thanks a lot for helping me out with this. And even more thanks doing the effort of adjusting the timestamp for my purpose! Appreciate it a lot!
You're right ofcourse, it's the other way around hahaha. It's verry late here already haha
But yes, I think I had to make a choice there back then. Because I used diffrent sources, and other camera's I used recorded in 50fps. And I'm sure if it's working like this. But I thought that it could be easier to revert 60fps to 50fps because it just needs to skip a few frames then. Then the other way around, converting 50fps to 60fps, missing 10 frames then. So probably duplicates a few frames then?
Keeping timestamp of edited / converted Video
By keyboard in forum Newbie / General discussionsReplies: 5Last Post: 30th Apr 2024, 01:10 -
Difference between lossless and lossy changing fps (timestamp vs encoding)
By precipizio in forum Blu-ray RippingReplies: 4Last Post: 23rd Feb 2022, 10:24 -
ffmpeg "Missing key frame while searching for timestamp" message
By the_steve_randolph in forum Newbie / General discussionsReplies: 0Last Post: 19th Aug 2021, 15:38 -
How to fix a timestamp overlap?
By WoundedPear in forum Newbie / General discussionsReplies: 2Last Post: 2nd May 2020, 04:00 -
Polaroid CUBE timestamp flaw?
By terrypin in forum Newbie / General discussionsReplies: 6Last Post: 9th Jun 2017, 17:17
