  1. I was using Internet Download Manager to download videos from Streaming sites Unprotected Videos
    but now my license has expired
    any other way to download videos without IDM ?
  2. search mpd or m3u8 link and download with yt-dlp
  3. Originally Posted by lomero View Post
    thanks but why the speed is soo slow compared to IDM ?
    yt-dlp downloading speed is 300 to 550 kbps
    while in idm i can get up to 4 mbps
    same video
  4. add aria2 to yt-dlp
    yt-dlp --external-downloader aria2c https://mpd
  5. Originally Posted by lomero View Post
    add aria2 to yt-dlp
    yt-dlp --external-downloader aria2c "https://mpd"
    download here http://aria2.github.io/
    and see your PM ...
    thank you so much it worked and downloading at full speed
    i just have 1 more question
    1-will yt-dlp by default download the highest quality available from the mdp link ?
    im using this command
    yt-dlp --external-downloader aria2c --allow-u --no-check-certificate mdplink
    2-can i make yt-dlp automatically merge the video and audio files into an mkv file after the download is complete ?
    thank you
    and thanks for the link
  6. 1) yes, by default yt-dlp download at best resolution, video and audio
    2) to merge use ffmpeg with
    ffmpeg-i video.mp4 -i audio.m4a -c copy final_video.mp4
    and please, read your PM ...
  7. Originally Posted by Loryanam2 View Post
    thank you
    if the videos are unprotected (no drm) then you dont need the '--allow-u' part.
    the added benefit to not using that is that yt-dlp will join the file automatically for you.
    for mkv you could try adding this to the yt-dlp command, which "should" merge the video and audio into a mkv instead of a mp4.
    --merge-output-format mkv
