Hi, I'd like to remove this logo.
https://www.dropbox.com/s/1kypjoib4khn8yn/delogo.png?dl=0
This is the sample: https://www.dropbox.com/s/6voklfwqi942s1u/I%20viaggiatori%20della%20sera_20220422_0405...sample.ts?dl=0
I've some written notes on about to use a certain procedure,, this one:
InpaintDelogo
- first it is needed to draw a mask to match the logo borders, using this command:
InpaintLoc(Loc="622,472,-62,-36")
- Include 10(no less) - 16 pixel borders around the logo.
InpaintLoc(Loc="606,456,-46,-20")
- then create the mask with this command:
InpaintDelogo(mask="D:\mask.bmp", Automask=1, aMix=0, Loc="606,456,-46,-20", Mode="Deblend", Analyze=2)
- add final command to the script
InpaintDelogo(mask="D:\mask.bmp", Automask=0, aMix=0, Loc="606,456,-46,-20", Mode="Deblend")
Script:
Code:LoadPlugin("C:\Users\antip\Desktop\util\MeGUI-2913-64\tools\ffms\ffms2.dll") FFVideoSource("C:\Users\\TS\ cutted.ts", fpsnum=25, fpsden=1, threads=1) #PAL 16:9 720 x 576 16:11 ITU ON crop(0,2,-0,-0) bbmod(2,0,2,2,128,8) Trim(80313,84058) #InpaintLoc(Loc="606,456,-46,-20") #InpaintDelogo(mask="C:\Users\\mask\mask.bmp", Automask=1, aMix=0, Loc="606,456,-46,-20", Mode="Deblend", Analyze=2) InpaintDelogo(mask="C:\Users\\mask\mask.bmp", Automask=0, aMix=0, Loc="606,456,-46,-20", Mode="Deblend") Prefetch(7)
I've tried this procedure one time only and I remember although it was effective on still frames, some logo shadows, remnants were still visible,
especially on dark scenes when I played the file, so the final result wasn't so good.
masks: https://www.dropbox.com/sh/ot6tqqaej66kkp5/AAAHZyofePJuVVKay1_Frdx1a?dl=0
What I would like to ask is:
is this procedure correct? Can it be improved?
How many pixels around the logo I should keep, 16 is fine? more, less?
Do you know some other better commands/procedures?
Any help is appreciated.
edit: first try, the logo is still visible sometimes and I don't know why the video is stuttering:
https://www.dropbox.com/s/n9wqvnyi41qykl8/1%20try%20-%20606%2C456%2C-46%2C-20%20.mkv?dl=0
new script
trying to make a slightly bigger mask, 20+px... InpaintLoc(Loc="602,452,-42,-16"), and adding more scenes..Code:LoadPlugin("C:\Users\antip\Desktop\util\MeGUI-2913-64\tools\ffms\ffms2.dll") FFVideoSource("C:\Users\\cutted.ts", fpsnum=25, fpsden=1, threads=1) #PAL 16:9 720 x 576 16:11 ITU ON crop(0,2,-0,-0) bbmod(2,0,2,2,128,8) Trim(60000,100000).SelectRangeEvery(400,50) #InpaintLoc(Loc="602,452,-42,-16") #InpaintDelogo(mask="C:\Users\mask\mask.bmp", Automask=1, aMix=0, Loc="602,452,-42,-16", Mode="Deblend", Analyze=2) #InpaintDelogo(mask="C:\Users\\mask\mask.bmp", Automask=0, aMix=0, Loc="602,452,-42,-16", Mode="Deblend") Prefetch(7)
this one seems much better, I don't see any big artifacts but somtimes the logo borders are visible and,
anyway the video is stuttering again, can't understand what's the problem..
https://www.dropbox.com/s/uc2otzhqx7403ei/test%202%20-%20602%2C452%2C-42%2C-16.mkv?dl=0
test3: https://www.dropbox.com/s/mjgo10kk03upy0v/test%203.mkv?dl=0
same settings as the test2 on other scenes, the logo artifacts are barely visible, quite acceptable, but can be done better?
help please.
Results 1 to 11 of 11
I can't check stuff without the full video [sound not needed].
Some notes:
Analyze=2 is default, so you adding it or removing it at some lines have same effect.
"Masks" you shared are not the masks.
Why you are doing some weird trims before InpaintDelogo?
Prefetch should be used only for encoding, not for masks creation.
Stuttering: could be FFVideoSource, try LWLibAvVideoSource, it should be frame accurate.
It's fine.Last edited by VoodooFX; 24th Apr 2022 at 11:17.
ok, I'm gonna remove the Analyze parameter. thx
I was trimming cause create the full length mask was taking ages, it was just a try. I now know it is needed the full mask process.
anyway I did it on the full movie and the masks now are these:
plus a very long txt file.
Should I redo the masks without the Prefetch line then?
If I'll get stuttering again, I'll try with that LWLibAvVideoSource(), never tried before, doesn't even never heard of it.
thx voodoo very appreciatedLast edited by maudit; 24th Apr 2022 at 15:42.
Of course. Delete all "mask" files created with Prefetch, before doing it.
Probably because of Prefetch.
https://github.com/HomeOfAviSynthPlusEvolution/L-SMASH-Works/releases/
Use it to do masks too: LWLibAvVideoSource("C:\Users\cutted.ts")
Copy plugins to your Avisynth's plugins folder so you don't need to add "LoadPlugin" to scripts. -
ok, I'll redo masks.
I've not fully understood that LWLibAvVideoSource part, anyway I think I already have an L-smash.dll 15MB sized into the avisynth plugin folder.
anyway about the stuttering, I've noticed that it happens when I handle TS files, with the TS file I also have some issues with the frame navigation and with some missing frames at start. (maybe libav can handle it better.... i'll try)
So I used the avidemux mkv muxer, instead of the TS muxer, on the first cuttings and now, handling the mkv on avspmod makes all smooth with no stuttering at all, no missing frames, good frame nav.
I'm gonna recreate masks with no prefetch line...
edit: I haven't timed, but it's taking ages, just like before with prefetch.Last edited by maudit; 24th Apr 2022 at 15:40.
Maybe your PC is slow, it's all down how fast your CPU can decode video.
I measured your sample with AVSMeter, my ooold CPU decodes it at 425 FPS, 1H 30Mins movie - ~5 mins, +Analyze would be less than 10mins.Last edited by VoodooFX; 24th Apr 2022 at 22:58.
well, using the mkv instead of the TS, the video no longer stutter, but
the logo artifacts, remnants are still visible on dark, high contrast, moving scenes..
and it was semi transparent, perhaps it is the maximum obtainable, I'll settle for it. -
No doubt.
I've re-read the manual and the parameters are not so many, anyway I have difficulties to understand how to use them exactly.
I should do several tests, and each one takes a lot of time.
I think I'm going to give up and keep the logo.
I use prefetch(7) cause someone else suggested in another thread,
he said something like to insert a number equal to the number of logic cores minus one.
But if you say it's wrong and it's making encodings slower, then I'd like to know your opinion, what number do you think I should use? 3? -
Nevermind, for some reason I thought that it's quad core.
Avisynth:remove logo flickering?
By marcorocchini in forum Newbie / General discussionsReplies: 1Last Post: 17th Dec 2021, 10:55 -
How to remove a logo without a smudge
By aruwin in forum EditingReplies: 7Last Post: 12th Dec 2020, 23:51 -
Remove Channel Logo with Ripbot
By Yonidan in forum Video ConversionReplies: 6Last Post: 28th Oct 2020, 14:47 -
How to remove logo from video
By FlameFusion in forum EditingReplies: 9Last Post: 25th Apr 2018, 23:15 -
How to Remove Logo From MKV File
By 09norcim in forum EditingReplies: 5Last Post: 9th Mar 2018, 05:59
