  1. hi, I have a little doubt which I can't solve by myself.
    I convert a DTSMA to AC3, using useac3to, changing the duration, the log file says:
    DTS Master Audio, 5.1 channels, 24 bits, 48kHz
    (core: DTS, 5.1 channels, 1509kbps, 48kHz)
    Decoding with libDcaDec DTS Decoder...
    Changing FPS from 23.976 to 24.000...
    Remapping channels...
    Encoding AC3 <640kbps> with libAften...
    Creating file "\audio\_track2_[eng]_DELAY 0ms.dts_24p.ac3"...
    The original audio track has a constant bit depth of 24 bits.
    The processed audio track has a constant bit depth of 64 bits.
    eac3to processing took 9 minutes, 1 second.
    Done.
    should I worry, add some command, about that 24/64 bits difference?
    mediainfo shows the bit depth on dtsma files, but not on ac3..
    how do I check the bitdepth of an ac3 file?
  2. Member Cornucopia's Avatar
    This was already answered in another thread.
  3. Originally Posted by Cornucopia View Post
    thank you, which one?
  4. Member Cornucopia's Avatar
    Yours. Different format but same kind of process.
    https://forum.videohelp.com/threads/405409-Converting-framerate-of-an-aac-Reducing-dep...ts#post2654334
    But you could do a search on bitdepth and find a number of similar threads that all describe it.
  5. Thanks, and sry about this similar question, there re so many things to recall these days, my fault, apologize.
