Hello everyone I am newbie in Burning DVD.The software i currently have is WINX DVD Author and i use HP disk with 4.7GB.The movie is in mp4 with 3.5 GB.I have tried a lot of tutorial from youtube none seems to help, iam down to my last HP DISK.Hope anyone could help me soon.Thank you.Appreciate anyone's and everyones's help.
Unless your mp4 file contains DVD compatilbe MPEG 2 video its size is irrelevant. It will be re-ended when made into a movie DVD. What matters is the bitrate you chose to encode at. If your software doesn't have a "fit to DVD" option you will have to set the bitrate yourself. Use a bitrate calculator. Or you can estimate the correct bitrate by dividing 9000 by the running time of the movie in hours. For example, a 100 minute movie is 1.67 hours. 9000 / 1.67 is about 5930. So encode at 5930 kbps.
friend i used Windows Media player and instructed like in this link is it the correct way to do it?https://www.videoconverterfactory.com/tips/how-to-burn-a-movie-to-dvd.html
The WMP method only copies the mp4 file as a data file to a data DVD disc. That tutorial also shows how to burn DVD-Video authored discs, and recommends Windows DVD Maker. While that is possible if you already have it, those of us in the know here much more recommend using ImgBurn to burn the disc. However, as mentioned in the tutorial, and as mentioned by jagabo above, you still would need to re-encode to MPEG and author for DVD-Video format, and that tutorial recommends DVD-Styler. There are a number of inexpensive or freeware authoring apps available, including DVD-Styler, and many of them have links listed on this site. Take your pick.
Remember, the process is:
Convert (Re-encode to MPEG, etc) --> Author --> Burn. These can be done by an all-in-one app or split up into multiple apps each doing their individual job. Usually the AIO is simplest but least optimal, while the individuals are most complex but most optimal.
Scott -
Burning a disk and keeping original dates
By keyboard in forum Newbie / General discussionsReplies: 4Last Post: 27th Feb 2022, 04:39 -
burn multiple iso movie files to blu-ray disk
By jimbo49 in forum Authoring (Blu-ray)Replies: 7Last Post: 16th May 2021, 13:12 -
Problem burning DVD format to disk
By Dave G in forum Newbie / General discussionsReplies: 2Last Post: 20th Feb 2021, 06:06 -
Burning a DVD Disk to Bluray Disk
By tarzan54 in forum Authoring (Blu-ray)Replies: 9Last Post: 3rd Sep 2020, 19:27 -
Why no juddering on 60hz Laptop LCD when watching 25p movie?
By Bencuri in forum Software PlayingReplies: 0Last Post: 25th Oct 2019, 18:15
