does anyone have a region hack for the LG DVD-3200E
8)
try this but it wont work if you have firmware 1.0
Firmware Check:
1. Press Setup button on the remote control.
2. Select TV Aspect.
3. Place the cursor on 16:9 wide.
4. Using the remote control, key in the following: 1, 3, 9, 7, 1, 3, 9.
5. Press Enter on the remote control.
6. Press "SETUP" to clear the information once read.
Region change:
1. Wait until the message "no disc" or "region coding error" appears before you proceed to step 2. You only have a second or two to enter the code below.
2. Press PAUSE, ENTER, 3, 1, 4, 1, 5, 9 on the remote control.
3. Press 0 for region-free, 1 for region 1, 2 for region 2, etc.
4. Press PAUSE on the remote control.
5. Power off the player for few seconds.
6. Power on the player.
VCD Enable:
1. Power on the player with no disc in the drive.
2. Press Pause on the remote control.
3. Using the remote control, key in the following: 1, 4, 7, 2 (the characters 01 47 should appear on the display) [If your player is a non UK model, this number will probably be different - don't worry]
4. Press the UP arrow three times (the characters 04 Fd should appear on the display)
[This number may be different depending on the configuration of your specific model - don't worry]
5. Press Program, 6, Program, 5 (the characters 04 FE should now be displayed).
6. Press Enter (the display should flash briefly).
7. Press Return.
8. Power the player off and then back on.
9. Play a VCD!
Yes for 3200E, 3230, 3830P, 4000A, 4210, 4710, 4830, DA-3520
cya
Richard StandenI want ADSL.....
1.7Km from BT Exchange (in a straight line)
2.0Km from BT Exchange (by road)
7.8Km of cable laied from BT Exchange to my house... Figure that one out?????
Hack working for Sony BDP-S380 region 1, to make it region free?
By Julieso in forum DVD & Blu-ray PlayersReplies: 0Last Post: 30th Dec 2011, 17:12 -
Euroline DVD100 DVD Player Region all region code/hack?
By mjgjhb in forum Newbie / General discussionsReplies: 0Last Post: 21st Jul 2011, 10:26 -
NON-region DVD player hack...
By cwb in forum DVD & Blu-ray PlayersReplies: 10Last Post: 24th Sep 2009, 17:53 -
Yamaha DVD w/HDMI remote hack? Region 1 to all region [PAL]?
By eurocd in forum DVD & Blu-ray PlayersReplies: 1Last Post: 27th Jul 2007, 13:58 -
help on region hack Philips DVD963SA from German to US/Multi region
By stieven in forum DVD & Blu-ray PlayersReplies: 0Last Post: 26th Jul 2007, 13:29
