  1. Hello
    I recently tried to install a Linux iso...I got to the end and pressed start to run it and i got the following. Can anyone tell me what the problem could be by the following screen Shot?
    https://forum.videohelp.com/#null
  2. I run windows in a Linux environment, the opposite way around to you but I think the problem is you have virtualization turned off in the BIOS settings.
    Try intercepting the boot process and enter BIOS setting to see if it can be configured.
    Brian.
  3. Thanks for reply betwixt
    Yes i think you could be right having looked on YT, however i've yet to try but will today.
    Thanks again much appreciated.
    Sep 2020
    Denmark
    I'm just learning what is virtualization technologies and so far I've encountered a similar error. If you find a practical solution, I will be grateful if you share your experience.
