My Panasonic AG-1970 is working fine but suddenly the clock is flashing 12:00. I pressed CLOCK and Pressed the Tracking + and Tracking - which is supposed to set the clock but it just keeps blinking 12:00.
When I turn it off it also just blinks 12:00.
I have also noticed too that now if I press the power button sometimes it turns on and other times it does nothing. I can turn it on 100% of the time with the remote so its not a big problem but just curious why sometimes the power button the unit works and other times it does nothing.
The unit plays fine but the flashing 12:00 and inability to set the time is maddening. Is there and internal batter that saves the time that perhaps I can replace.
Thanks All
	Is it 28 years old? Extraordinary claims require extraordinary evidence -Carl Sagan
	Failing components i'd say, capacitors or else. You may want to reach a pro that can do a recap. *** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE
	Since the whole point of the clock is for scheduling channel recording, and since such analog channels are long since defunct, making the feature unusable, you could just disconnect the clock and be done with it.
  8mm digitalization - Picture is either blinking or black and whiteBy ther89 in forum Capturing and VCRReplies: 10Last Post: 1st Feb 2022, 06:26
  Forum searches show date as 1st Jan 1970By Brad in forum FeedbackReplies: 9Last Post: 22nd Nov 2021, 12:29
  Ag-1970By jbandes in forum Newbie / General discussionsReplies: 1Last Post: 16th Jul 2021, 02:02
  Panasonic AG-1970: Is it worth getting repaired???By crissrudd4554 in forum Capturing and VCRReplies: 4Last Post: 8th Jan 2020, 04:25
  Blinking VHS-C Video Conversion, PLEASE HELPBy dward1222 in forum Video ConversionReplies: 19Last Post: 9th Apr 2018, 05:02
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
