I'm trying to capture Hi8 ntsc tape using huffyuv codec on window 10/AmarecTV
I wonder what the field threshold should be set to.
When I searched on Google, the story was different for each person, such as 240, 288, 480.
What is the right choice?
Also, is it correct to uncheck the enable full size output buffer setting?
In for a penny......
Consider that you are capturing full frame interlaced which would be 720*480 for NTSC and 720*576 for PAL. Each of these full frames are made up of two fields with a height of 240 for NTSC and 288 for PAL. So it is these numbers that are the settings for full-frame depending on the source.
TBH I do not have a clue what 'enable full size buffer' is or does. But logic dictates that if you are capturing full size - and I assume that means the same as above - then you should keep the option checked.
Hard hat firmly on
My recommendation is to stay away from apps that are so poorly written that they are confusing even to long-timers.
Scott -
Default (288). It should never have been exposed as a user setting. The original author's involvement ended at the final official version: Huffyuv 2.1.1.
This setting was offered as part of patches put out by random programmers who "updated" the official Huffyuv 2.1.1 to other variants including 2.2.0 (which sounds official, doesn't it?).
I explained the situation here: http://www.digitalfaq.com/forum/video-capture/6620-test-avi-file-3.html#post38937
It's to fix a crash, so if you don't get any crashing with the option disabled, that means you're not encountering the scenario it was meant to address. In which case, there is no harm to disable it.Also, is it correct to uncheck the enable full size output buffer setting?Last edited by Brad; 13th Apr 2022 at 19:14.
My YouTube channel with little clips: vhs-decode, comparing TBC, etc.
Invert field order using ffmpeg for NTSC source
By cjdavis83 in forum LinuxReplies: 0Last Post: 28th Dec 2021, 07:51 -
PAL and NTSC hi8 player
By jonbang in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 18th Mar 2021, 15:51 -
Huffyuv Codec Problem?
By MrJacobAngle in forum Software PlayingReplies: 13Last Post: 20th Aug 2020, 18:01 -
Capturing Hi8 tapes
By TheDrifter363 in forum Capturing and VCRReplies: 46Last Post: 2nd Feb 2020, 13:18 -
where the HUFFYUV codec save it's configuration?
By marcorocchini in forum Newbie / General discussionsReplies: 2Last Post: 26th Jun 2018, 09:27
