hi, I need some help.
situation: I have a series of Loops which I use in a script in order to edit an audio file.
it works well but due to three of these Loops are too much long, they produce bad sound effects.
my idea is, instead of duplicate the frames, I'd like to add blank frames with no audio, or better, to use a command like
killaudio in order to cancel any audio at those frames.
so please, can you help me to find the best and simple way in order to replace these following three bolded Loops into frames with no audio?
Code:LoadPlugin("\Desktop\util\MeGUI-2913-64\tools\ffms\ffms2.dll") Video=FFVideoSource("C:\cutted - no aac.mkv", fpsnum=25, fpsden=1, threads=1) Audio=FFAudioSource("C:\cutted - no aac.mkv") AudioDub(Video,Audio) Loop(2,3797,3797).Loop(0,5536,5536).Loop(2,5536,5536).Loop(3,5754,5754).Loop(3,5757,5757).Loop(4,25509,25509).Loop(6,25513,25513).Loop(7,51483,51483).Loop(5,51490,51490).Loop(34,71471,71471).Loop(29,71505,71505) Loop(2,91621,91621).Loop(6,101038,101038).Loop(6,101044,101044).Loop(40,123744,123744).Loop(6,123784,123784).Loop(0,126031,126031)
Results 1 to 11 of 11
You can't killaudio(), because that removes the audio track . You can't splice a stream with audio and video tracks, to one with just a video track
maybe add .amplify(0) to each, which will make it silent audio
EDIT: I missed the part about blank frames
I would organize it to reference which video/audio you're referring to
Code:LoadPlugin("\Desktop\util\MeGUI-2913-64\tools\ffms\ffms2.dll") Video=FFVideoSource("C:\cutted - no aac.mkv", fpsnum=25, fpsden=1, threads=1) Audio=FFAudioSource("C:\cutted - no aac.mkv") AudioDub(Video,Audio) a=last b=blankclip(a)
For each normal section use a.Loop(....)
For each blankclip with blankaudio section use b.Loop(...)Last edited by poisondeathray; 13th Apr 2022 at 10:55.
@poisondeathray,
thank you, I got the sense of your suggestions but I have difficult to understand their usage, their syntax,
can you please make a couple of examples?
I mean, for the command ".amplify(0)", you mean like this?
or maybe, idk, the amplify command goes inside the Loop parenthesis?Code:Loop(2,3797,3797)....Loop(34,71471,71471).amplify(0).Loop(29,71505,71505).amplify(0)... .Loop(6,101044,101044).Loop(40,123744,123744).amplify(0).Loop(6,123784,123784)..
and about that other way you mentioned, I'm not sure I have fully understood the usage of the "last" special variable.
what's inside this variable?
you mean like this?
Code:A=last B=blankclip(A) A.Loop(2,3797,3797)....B.Loop(34,71471,71471).B.Loop(29,71505,71505)... A.Loop(6,101044,101044).B.Loop(40,123744,123744).A.Loop(6,123784,123784)..
Ignore the amplify comment, because I misread that you wanted black frames over those frame range
a="last" means everything written before is now assigned the variable a
In the example below, b_loop=last is the same video, but with blank frames and blank audio. You could have used another variable name if you wanted to
You can use remapframes to mix&match versions . You only have 3 frame ranges in this example, but it's a handy function to use, especially when you have multiple ranges
Code:LoadPlugin("\Desktop\util\MeGUI-2913-64\tools\ffms\ffms2.dll") Video=FFVideoSource("C:\cutted - no aac.mkv", fpsnum=25, fpsden=1, threads=1) Audio=FFAudioSource("C:\cutted - no aac.mkv") AudioDub(Video,Audio) a=last b=blankclip(a) a Loop(2,3797,3797) Loop(0,5536,5536) Loop(2,5536,5536) Loop(3,5754,5754) Loop(3,5757,5757) Loop(4,25509,25509) Loop(6,25513,25513) Loop(7,51483,51483) Loop(5,51490,51490) Loop(34,71471,71471) #71471 to 71504 Loop(29,71505,71505) #71505 to 71533 Loop(2,91621,91621) Loop(6,101038,101038) Loop(6,101044,101044) Loop(40,123744,123744) #123744 to 123783 Loop(6,123784,123784) Loop(0,126031,126031) a_loop=last b Loop(2,3797,3797) Loop(0,5536,5536) Loop(2,5536,5536) Loop(3,5754,5754) Loop(3,5757,5757) Loop(4,25509,25509) Loop(6,25513,25513) Loop(7,51483,51483) Loop(5,51490,51490) Loop(34,71471,71471) #71471 to 71504 Loop(29,71505,71505) #71505 to 71533 Loop(2,91621,91621) Loop(6,101038,101038) Loop(6,101044,101044) Loop(40,123744,123744) #123744 to 123783 Loop(6,123784,123784) Loop(0,126031,126031) b_loop=last RemapFrames(a_loop, mappings="[71471 71504] [71471 71504] [71505 71533] [71505 71533] [123744 123783] [123744 123783]", sourceClip=b_loop) -
ok, now is a bit more clear, the code above replaces those ranges with blank frames.
it is a bit complicated and still pretty hard to understand:
in particular I cant get the syntax of:
you saidCode:a Loop(..) Loop(..) ... a_loop=last
so, a_loop=last means in a_loop now there is everything written before? or just from the "a"?a="last" means everything written before is now assigned the variable a
it looks like a bit redundant and I can't fully get it yet.
are you sure this is the simplest way to mute those ranges?
I do not need those ranges are blank, I just need their audio is silenced.
can't I just use ".amplify(0)" in some way?
this code below or something similar, won't work?
Code:Loop(2,3797,3797).Loop(0,5536,5536).Loop(2,5536,5536)...... Loop(34,71471,71471).amplify(0).Loop(29,71505,71505).amplify(0) Loop(2,91621,91621).Loop(6,101038,101038).Loop(6,101044,101044) Loop(40,123744,123744).amplify(0) Loop(6,123784,123784).Loop(0,126031,126031)
Now I'm confused
Yes, that replaces those ranges with black video frames, and silent audio
Earlier-
I understand the audio part.
What about the video frames? Did you mean duplicate blank (black) frames replacing original frames, or duplicate original frames (the video, not the audio)?
It means from everything from a to a_loop=last
Before you were using "implied last"
Loop(2,3797,3797).Loop(0,5536,5536)....
Really means
Loop(last,2,3797,3797).Loop(last,0,5536,5536)....
Where "implied last" refers to AudioDub(Video,Audio) . Because "last" is implied, it can be omitted.
But consider the case where you were mixing/matching different versions. Which "last" are you using ? Which video or audio are you referring to ?
For this:
Loop(..) really means Loop(last, ....) ; Since "a" was called and preceded Loop() , "a" is implied "last"Code:a Loop(..) Loop(..) ... a_loop=last
So that really means
Loop(a, ...)
Loop(a, ...)
a_loop=last
and a_loop is the new variable name for "a" with all the loops applied
Not like that, because it will mute the entire audio, and it doesn't give you duplicate black video framescan't I just use ".amplify(0)" in some way?Last edited by poisondeathray; 13th Apr 2022 at 19:25.
Another way you do it is with trim
Assuming black duplicate frames
Code:AudioDub(Video,Audio) Loop(2,3797,3797) Loop(0,5536,5536) Loop(2,5536,5536) Loop(3,5754,5754) Loop(3,5757,5757) Loop(4,25509,25509) Loop(6,25513,25513) Loop(7,51483,51483) Loop(5,51490,51490) Loop(34,71471,71471) #71471 to 71504 Loop(29,71505,71505) #71505 to 71533 Loop(2,91621,91621) Loop(6,101038,101038) Loop(6,101044,101044) Loop(40,123744,123744) #123744 to 123783 Loop(6,123784,123784) Loop(0,126031,126031) a=last b=blankclip(a) a.trim(0,71470) ++ b.trim(71471,71533) ++ a.trim(71534,123743) ++ b.trim(123744,123783) ++ a.trim(123784,0)
If you didn't want black duplicate frames, but you wanted duplicate original frames, just silent audio over those sections
Code:AudioDub(Video,Audio) Loop(2,3797,3797) Loop(0,5536,5536) Loop(2,5536,5536) Loop(3,5754,5754) Loop(3,5757,5757) Loop(4,25509,25509) Loop(6,25513,25513) Loop(7,51483,51483) Loop(5,51490,51490) Loop(34,71471,71471) #71471 to 71504 Loop(29,71505,71505) #71505 to 71533 Loop(2,91621,91621) Loop(6,101038,101038) Loop(6,101044,101044) Loop(40,123744,123744) #123744 to 123783 Loop(6,123784,123784) Loop(0,126031,126031) a=last b=a.amplify(0) a.trim(0,71470) ++ b.trim(71471,71533) ++ a.trim(71534,123743) ++ b.trim(123744,123783) ++ a.trim(123784,0)
And for that other version, b_loop could have been simplified instead of repeating all those loop statements
Code:b_loop = blankclip(a_loop)
yes, maybe I was not so clear, I mentioned blankclip cause it came to my mind and I thought it was useful for my purpose.
but if it is such complicated I prefer to use another method.
the purpose of the script, is that given that series of loops, it has to mute three of them.
I'm only interested in the audio track, doesn't matter about the video.
I didn't thought it was so complicated as well, but I'm gonna try your last code.
edit: anyway about the last line:
a.trim(0,71470) ++ b.trim(71471,71533) ++ etc
can be written this way too?
trim(a,0,71470) ++ trim(b,71471,71533) ++ etcLast edited by maudit; 13th Apr 2022 at 20:58.
thank you poison, sry for the delay, I tried your method and it works.
at the end I will not use it, cause those silenced parts are not so good to ear.
So I will try to loop the video in some other way.. I'm still working on it, is not so simple as it seems...
Anyway.. thank you very much for having explained those scripts examples, they can be very useful for future works.
Thanks a lot.
AVISynth: How do I make BlankClip the same framerate?
By smike in forum EditingReplies: 1Last Post: 16th Oct 2021, 16:20 -
Potplayer low cpu usage
By arnob216 in forum Software PlayingReplies: 2Last Post: 2nd Apr 2021, 22:13 -
CPU Usage is Low
By wes93 in forum Video ConversionReplies: 2Last Post: 4th Sep 2020, 11:06 -
RGTools for Avisynth Usage
By VideoFanatic in forum Video ConversionReplies: 2Last Post: 27th Mar 2018, 11:06 -
Not full cpu usage on My pc
By mromagno in forum Software PlayingReplies: 5Last Post: 31st Jan 2018, 11:16
