hii, i need help to make my own simple lossless video audio encoder/decoder
which just do simple task like..
take same resolution image/frame sequence and audio track as source and wrap them in wrapper mp4 or any other wrapper without lossing quality
i have learned C programming language in school ,so i have basic understanding of C language how to compile c programs and run it
i just need code which can do this task.which just do simple task like..
Results 1 to 11 of 11
AnonymousGuest
I hate to burst your bubble, but I'm going to. You think this is simple - it is not.
It sounds like you want someone to give you the code. Other than freely available open source (which you should already be able to get), this is something you either are going to have to code yourself or hire someone to do for you.
My suggestion is first start simply with not doing an encoder or decoder (they are 2 complementary things) but doing a muxer and demuxer. Use directshow API hooks or similar. Once you have that down (which in itself is not easy either), then you can graduate to encoding/decoding. That is more difficult, because you will need to fully understand not just the coding, but how to deal with interlacing, color subsampling, non-square ARs, RGB vs. YUV conversion, etc.
Good luck. You will need it.
Scott -
AnonymousGuest
i have a simple logic to make things works for video only
folder of image sequence
and a program which plays that image sequence in desire fps
but for audio i have no idea
and to pack files(image sequence and audio) in container ,we can make .bin file i guess
so that program will read that bin file and display data from it. -
AnonymousGuest
i was looking for a c program online which displays image which in current directory but didnot found anything helpful
is it posible to display image with c program??
i think it requires something ,Qt is a widget toolkit for creating graphical user interfaces ,idk much about it. -
What do you mean by that, exactly
Displaying images inside a window or a "form" can be easily done with AutoIt, or even with the newbie-friendly Visual Basic...
But using a REAL
programming language probably requires direct calls to the specific API(s) of the operating system(s) involved — I guess.
And no, you don't need Qt at all for anything... If you ever need cross-platform portability, you'd better be using Java.
"Programmers are human-shaped machines that transform alcohol into bugs." -
AnonymousGuest
i dont know much about AutoIt and java
i know about C language
thats why i wanna write a program in C language which display animation of images present in current directory
back in 90's nintendo(nes), gameboy(.gba)games were also written in c language i guess
so i just wanna write basic program which animates image sequence
there was also one more thing 8 bit games and 16 bit games
am not sure but, this 8 bit and 16 bit specifies about graphics or pixel i guess -
AnonymousGuest
uhmm forgot about C language
i just want simplest program code that plays image sequence in 24fps or any desire fps
any language will be ok -
But Qt is cross platform, it is widely used for GUI's. I use it as pyqt because using python module, but apps use it as straight as C.
As Scott (Cornucopia) already said, it's not simple, and functional open-source code already exists.
Assuming you mean what you said,i just want simplest program code that plays image sequence in 24fps or any desire fps
you might start by studying Avisynth's and/or Vapousynth's source-codes."Programmers are human-shaped machines that transform alcohol into bugs."
VVC (H.266) encoder and decoder
By Harri123 in forum Newbie / General discussionsReplies: 0Last Post: 13th Feb 2021, 10:37 -
one audio language option vanished, in a dual audio track IN VLC mdia plyr
By jraju in forum Newbie / General discussionsReplies: 0Last Post: 28th Dec 2019, 06:43 -
Lossless to MP4 Simple FFMPEG Commend.
By dellsam34 in forum Video ConversionReplies: 28Last Post: 6th Mar 2019, 22:15 -
Need a simple video editor/encoder software
By meis in forum Newbie / General discussionsReplies: 1Last Post: 4th Mar 2018, 21:45 -
DVD authoring with [Language Menu] for each [Language Audio]
By Meem in forum Authoring (DVD)Replies: 6Last Post: 23rd Sep 2017, 03:32
