  1. This is something I could really use some help on, especially in modern times. I'm trying to make an ISO image out of these two VOB files so I can try to rip the video as an MPEG-2:
    https://archive.org/download/die-muppet-show-german-mary-roos-chris-langham-brooke-shi...isLangham1.VOB
    https://archive.org/download/die-muppet-show-german-mary-roos-chris-langham-brooke-shi...isLangham2.VOB
    However, I realized something was missing on my first try on ripping it with Magic DVD Ripper, and this was after I made an ISO. The IFOs and BUPs. I was wondering... Does anyone know any good software I could use to recreate the IFOs and BUPs, given the era we're now in? If so, please let me know.
  2. DECEASED
    Jun 2009
    Heaven
    DGIndex should be able to extract the video and audio streams from the .VOBs.
    Then you can create an appropriate DVD-Video structure (.IFOs + .BUPs + .VOBs) with an authoring tool
    (Muxman, dvdauthor, DVD-lab Pro, etc).
    "Programmers are human-shaped machines that transform alcohol into bugs."
  3. Originally Posted by El Heggunte View Post
    Thanks! I'll try what you mentioned, and I'll let you know of the results.
  4. Originally Posted by EditingFan12 View Post
    Also, since I'm new to DGIndex and Muxman, would you mind giving me some tutorials related to both softwares? I'd like to know how to do everything properly.
  5. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    VOB files ARE MPEG2.
    Try opening them in something like AviDemux(ignore the name of the program....it works on almost anything)....and "Save As" MPEG-TS(? I believe).....call it newfile.mpg or something and let it do it's thing.
    I think even HandBrake and WinFF can still do this too.
    Aug 2006
    AVStoDVD is easy to use and can create DVDs with a simple menu or no menu. I seem to recall that it accepts VOBs as input but I never needed to join the VOBs so I don't know if AVStoDVD does that. There are tutorials for AVStoDVD available. Links to some of them may be found on the VideoHelp software page for AVStoDVD.
  7. Well, I managed to figure it out. Thanks a lot, guys!
