Basically what the title says. I'm trying to use the pixel sorter to sort some of the pixels in an image, but not all of them. However, no matter what I do with the "start sorting" and "range" parameters, it sorts the entire thing. Even a range of 0 does this.
Here's a screen recording showing what I mean.
I've tried contacting UtaUtaUtau, but his plugin is running on someone else's script...and the GitHub page for it is in Japanese. The other plugin I don't know how to contact the author, but considering the language of the page I found it on, I think it's safe to say there would also be a language barrier.
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
https://utautautau.carrd.co/#others
Seems to work ok for me. Did you follow the instructions about the prerequisites ?
Uta's Test PixelSort has an extra requirement, which can be found here! Guide Video -
I'm using the "AviUtl_ExtraPack1-10[Win7]Release" portable version from Maverick.
I unzipped the Uta archive into a Uta folder, and cut/pasted the folder into the aviutl scripts folder.
https://cdn.discordapp.com/attachments/686984593878155307/879709637899857920/Uta.rar
Then copied PixelSorter_s.dll, lua51.dll from Maverick's archive into the Uta folder
https://github.com/MaverickTse/PixelSorter_s/releases/download/1.6EN/PixelSorter_s-EN.zip
It works ok from on some test pngs, including a vertical gradient shown in your video. Not sure what else to suggest -
I have the exact same version of everything. I don't know what I'm doing wrong
Audio problems with AviUtl
By ChasVideo in forum EditingReplies: 0Last Post: 31st Jul 2021, 18:19 -
MPC-HC: Output dynamic range / black level / color range stuck? Washed out
By vlad992 in forum Newbie / General discussionsReplies: 16Last Post: 10th Nov 2020, 07:54 -
Full Range to Limited Range Video
By chris319 in forum Video ConversionReplies: 42Last Post: 12th Aug 2020, 10:00 -
NVenc in AviUtl
By smartel in forum Newbie / General discussionsReplies: 0Last Post: 4th May 2020, 12:23 -
Bluring an area with AviUtl
By ChasVideo in forum EditingReplies: 1Last Post: 25th Dec 2018, 20:41
