Hi folks, looking for a recommendation on a VLC substitute.
Short context: I’ve come across a system where VLC is failing to play on a second monitor. I’m very familiar with VLC and applied the same documented settings as another working system has, but for some reason this particular PC is having issues and will only play on Display 1. I’m ready to cut my losses and move on.
Requirements:
Controller UI on primary monitor
One-click play that shows video full screen on second monitor
No ads (or able to purchase an ad-free version)
Plays well with other apps also using the second monitor
Not an orphan (updated at least every few months)
Windows 11 OS
Before I start testing a bunch of apps, thought I would ask what the most popular ones are that would support this. Thanks in advance!
Results 1 to 1 of 1
Search other video player (beside VLC) which support UpNP from MediaServer
By pxstein in forum Video Streaming DownloadingReplies: 1Last Post: 2nd Jan 2021, 19:54 -
VLC player alternative?
By videdit in forum Software PlayingReplies: 3Last Post: 19th Dec 2020, 18:31 -
VLC on new computer...still no Blu-Ray support?
By gastrof in forum Newbie / General discussionsReplies: 4Last Post: 26th Apr 2020, 03:33 -
any way to make VLC to scale back videos as big as my monitor by default
By StarTrek1 in forum Software PlayingReplies: 4Last Post: 10th Oct 2019, 15:02 -
Tsmuxer newer version that support truehd audio? Or any alternative program
By fits79 in forum Blu-ray RippingReplies: 7Last Post: 20th Apr 2019, 20:42
